2008paul
0
Annex M / Annex L
[ Edited ]
Hi there,
I have a Bipac 7800N that got settings for Annex M & Annex L and if I enable them it says I'm still using Annex A.
I've had a look on a site and it says the extange I'm connected too dose have Annex M.. So why is it I can't use it? Do I have to ask to be moved onto it?
Also, is they anyway to check if Annex L is on the extange?
Thanks,
Paul
Download: 6.48 / Upload: 0.87 :smileyhappy:
Guru
toekneem
0
Re: Annex M / Annex L
[ Edited ]
Hi Paul,
I am sure I saw a post the other day about Annex M. I think they was told it was for Business.
[edit] yep here it is:
http://community.bt.com/t5/BB-Speed-Connection-Issues/Annex-M/m-p/294487#M97963
toekneem
(EASBF)
Sage
john46
0
hi yes annexe M is a business service
If you want to say thanks for a helpful answer,please click on the Ratings star on the left-hand side If the reply answers your question then please mark as ’Mark as Accepted Solution’
