Newbie
nuskit
0
How can I turn off wireless
Hi,
I want to turn off the wireless network on my bt home hub but when I go into the HH interface there's no option to turn it off. Its a HH 2 with 1 hub phone attached.
Any ideas please.
Thank you
Sage
Keith_Beddoe
0
Re: How can I turn off wireless
[ Edited ]
You cannot turn the wireless off without losing your free BTOpenzone and FON access when you are out and about.
If you opt out of this service, then you will be able to disable wireless.
The wireless network on the HH 2 is very secure, if you are turning it off for that reason.
Expert
hamish72
0
[ Edited ]
unless you use fon when you cant
enter
192.168.1.254 in browser click A to Z top right  (hub pass word )
then
wireless connection enable disable
and do it there
POST RESULTS
Also post results of test at http://speedtester.bt.com/
If any post helps tick the star box on the left
Just cause Im paranoid dont mean they are not out to get me
Newbie
nuskit
0
I have already disabled FON, whats BTOpenzone do I have to disable that as well?
These is still no option to disable wirless
Newbie
nuskit
0
There is no option to enable/disable wireless?
Expert
hamish72
Dont think fon is disabled instantly may take a day or longer and a hub rest may be needed when it is
Sage
Keith_Beddoe
0
Reset hub back to factory settings, this should clear the configuration file entry for FON.
