on 04-02-2012 18h20
Hi RealCynic,
The first thing is if you don't want to use Fon you do not have to, all our customer are free to opt out of the services if they wish.
The Fon usage is separate from your Broadband usage, as it has its own SSID. This means any Fon usage over the BT Network is identifiable as being from a Fon connection. If the usage is shown in you Hub manger this is because it is your Hub that is broadcasting the signal. The usage meter in the Hub will only give you a view of how much data has been sent via the Hub and does not give you a breakdown of how it was used, this happens on the BT Network.
I understand there might be a few things you don't like about Fon and that fine. You do have to remember there is a lot of our customers that find the service great and is the reason they have signed up to BT.
Cheers
Paddy
on 05-02-2012 17h38
I got BT Infinity on Friday and the BT Fon status was disable right up until today when I nearly exploded with angry, as when I was signing up I asked the BT Sales person in the BT Shop (who put the order though on a computer) to ensure BT Fon isn't activated at all because I wouldn't need to use it at all, as like nearly even one I have a Smartphone and I also have a 3G Modem so I really wouldn't use the BT openzone or BT Fon networks.
When the modem and Home Hub was send up (or rather plugged in by the engineer and ensured it was working he disappeared)I when onto it to configure the device including setting up ip address ranges (on all my networks I used 10.14.*.* then it stated I couldn't configure my own hub with addresses I wanted so, I forgot about it and just configured the wifi etc etc....
I checked and the BT Fon service was shown a status as Disabled.
Now today my wifi shows that the hub is shown 3 names (my network, BTFon and BT Openzone).
The last time I checked what BT are doing could be classed as "abstraction of electricity" as if you connected to a open network that you didn't have authorisation to that's what the owner can go to Civil court with. Never mind if it is showing the same Public ip as you own the if someone is downloading illegal contain Its going to be our heads as BT will claim it wasn't them. Complete BS that BT will force this onto customers.
I know that previous post put you can just select your own network rather then getting wind up with BTFon/Openzone, but the OP asked was there a way to remove the BT Fon Service from the Hub not any ideas to work around it.....
Its just BT doing what they want to do, I plan to ask to speak to a supervisor and ask them to disable BT Fon on my account right away as I did Opt Out when I was signing up and considering most addition things are Opt in rather then Opt Out.
I am very disappointed in BT not integrating a Disable button within the Hub itself rather then having to go onto another site or talk to BT.
I'm planning to contact OFCOM and make a official complaint of this.
on 05-02-2012 17h57
on 06-02-2012 12h13 - last edited on 06-02-2012 12h26
There are strong feelings about this issue and possibly some misunderstanding/misinformation on both sides. However, there are certainly issues that need addressing.
As a new BT broadband user, I see the major points as these:
1) I am never going to use the BTFON service, so I do not want to be part of it and I should not have been signed up to it without my knowledge or agreement. That is simply wrong. To say "you can unsubscribe" is plain silly - try the same argument with unsolicited emails. I have just discovered I was signed up to BTFON and have unsubscribed on the BTFON webpage as previously described. Apparently I now have to wait 48 hours for my HH to be remotely updated and the services removed. (N.B. you need to unsuscribe your primary email address and any secondary ones as well).
2) The fact that the HH can have its settings altered remotely raises even more issues. Once the above update has been done, how do I block off the remote access and or the ports it uses?
3) There appears to be no obvious way to locally disable the extra unwanted wireless services on the Home Hub (HH3 in my case) - there should be.
4) If you are on a rural bit of copper like I am - you need all of your bandwidth, (only 4Mbps in my case), I do not want an unknown number of users reducing my already pitiful speed - it makes speedtests totally meaningless as you don't know who else is using your bandwidth at the time of the test.
5) Do you trust the BTFON and remote control systems not to have any security bugs? I certainly do not. In fact a little bit of research reveals "Home Hub 3 serious security flaws for users".
You have to ask yourself why BT give away these Home Hubs, (apart from the £6 delivery charge, of course). Despite BT's advertising puff - there is nothing special about the Home Hub apart from its well hidden stealth options - it's based on the French Thomson Speedtouch hardware and firmware.
If you don't like the way BT have gone about this, and as a result don't trust BT or the HH, the best option is to replace it with a good off the shelf Wireless N router/adsl gateway. That is the real customer choice.
on 06-02-2012 12h24
on 06-02-2012 12h46
Thanks for that - my reply was mainly to PaddyB's post.
You don't answer many of the points I made.
No matter how many times you say "you can opt out", it is no answer to the basic argument that you should not be signed up to services without your knowledge as I was. Mind, I can appreciate the reason it's done this way; if it was done the more ethical 'opt-in' way then the network would probably never get set up....
The 512k info. just raises more questions. Is that 512k per user? (assuming that the connection is not being used by the main user at the time). How many users are allowed at any one time? What happens if the main user then comes on line wanting to download software or stream a movie, say? Is/are the BTFON user(s) unceremoniously kicked off? Even 512k is a big lump if you are only on 4Mbps. Many rural users are on even less.
on 06-02-2012 13h10
bobbear wrote:Thanks for that - my reply was mainly to PaddyB's post.
Incorrect. When the network was set up customers had to opt in. It was well established when, for whatever reason, BT changed it to opt-out.
It's a total of 512 Kbps. Just opt out and the rest of this is irrelevant (and the idea of multiple users at the same time is rather fanciful, especially out in the sticks).
on 06-02-2012 13h13
on 06-02-2012 13h34 - last edited on 06-02-2012 13h47
bobbear wrote:There are strong feelings about this issue and possibly some misunderstanding/misinformation on both sides. However, there are certainly issues that need addressing.
TBH, I agree, suppliers of a service (not just Fon) should not assume everybody wants that service and therefore should not automatically opt anyone in to that service.
Again, I agree
It can take up to 72 hours, sometimes much longer, then the Fon map doesn't always get updated and then the map falsely reports a hotspot. Only your primary email address can be used to gain access to a Fon/Openzone hotspot, no secondary email details can be used.
Hmm, that's been happening for a long time
There are ways to unlock the early type hubs, as can the HH2's and more recently the HH3's. For obvious reasons BT won't like to hear this. Not too sure atm what gets blocked on an unlocked HH3 - time will tell.
That's the same for the HH2 - in fact you can't even turn off your own SSID on the HH2 if you're a member of Fon
The 512kbps (total, not per user) will be reduced to the Fon user should you need more of your bandwidth - worst case, the user gets their Fon connection dropped all together
Ah, that'll be the port 161 debate....
on 28-02-2012 10h32
Comment to John46 - Do you ever read what people actually write ? Your comments do not appear to be a sensible answer to the posts. How much do BT pay you ?
Note about - Optin/Optout - FACT - Several people I know have recently started using BT for home Internet - every one has received a new BT HomeHub and all have BT FON and Openzone enabled by default.
I use BT Business Broadband - Using the supplied BT 2700 HGV router - that arrived with Openzone enabled - you have to physically disable it. It should arrive turned off !!!!! When they updated the firmware - they turned Openzone back on !!! Cheek !!!!
The current BT TV advert where they claim 2million hotspots where you can get free access - should be subtitled - access that we do not really have a right to use 'cos it belongs to someone else !
BT = Crooks
MikeJ
