Newbie
Jammydodgerman
0
Packet Loss?? Need help!
Over the past week I've been getting massive problems when gaming online with iRacing. I get halfway through a race and then I get kicked due to packet loss.
I did some ping tests and sure enough im losing between 2-5% of the total packets that were sent. This has made online gaming nearly impossible.
Any help to fix this problem would be greatly appreciated
Moderator
DavidM
0
Re: Packet Loss?? Need help!
Hi Jammydogerman,
Welcome to the forum and thanks for posting. Is the problem affecting any other part of the connection? Can you run a speed test at www.speedtester.bt.com and post the results? Can you also run a tracert and post the results of that as well? That will give us an idea of what’s going on.
Cheers
David
BTCare Community Mod
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on the left-hand side of the post.
