crispy_roll
0
Accepted Solution
Strange problem with broadband. Speed very low.
Hi all,
From last Friday I encountered really big problems with my broadband as the speed go dramatically down. I don't know what may be the reason, I'm using HomeHub and between it and computers in my household everything is fine. I haven't heard about any fixes round Aberdeen so have completely no clue what is going on.
Do you have any clue what can cause the problem, for more than 3 years everything was just great. Maybe my HomeHub is old and faulty, it is the 1st gen, white one.
I post speedtest results and ADSL info:
 Download speedachieved during the test was - 134 Kbps
 For your connection, the acceptable range of speedsis 4000-21000 Kbps.
 Additional Information:
 Your DSL Connection Rate :18761 Kbps(DOWN-STREAM), 888 Kbps(UP-STREAM)
 IP Profile for your line is - 16000 Kbps
The throughput of Best Efforts (BE) classes achieved during the test is - 0.0:75.22:25.5 (SBE:NBE:smileytongue:BE)
These figures represent the ratio while sententiously passing Sub BE, Normal BE and Priority BE marked traffic.
The results of this test will vary depending on the way your ISP has decided to use these traffic classes.
Upload speed achieved during the test was - 692 Kbps
 Upstream Rate IP profile on your line is - 888 Kbps
DSL Connection
Link Information
Uptime:3 days, 22:26:20
Modulation:G.992.5 annex A
Bandwidth (Up/Down) [kbps/kbps]:888 / 18,762
Data Transferred (Sent/Received) [MB/GB]:350.53 / 4.65
Output Power (Up/Down) [dBm]:11.5 / 0.0
Line Attenuation (Up/Down) [dB]:4.5 / 14.0
SN Margin (Up/Down) [dB]:15.0 / 5.0
Vendor ID (Local/Remote):TMMB / IFTN
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
Loss of Link (Remote):0
Error Seconds (Local/Remote):0 / 0
FEC Errors (Up/Down):0 / 246,017
CRC Errors (Up/Down):0 / 46
HEC Errors (Up/Down):0 / 39
Line Profile:Fast
Sage
imjolly
0
Re: Strange problem with broadband. Speed very low.
Newbie
mill2
0
[ Edited ]
same here for the past days my speed has been going slow i keep phoning up and all am geting is them telling me that they will send some one out to have a look. i had two out and i am geting the same did a speed teat on the speedtester.bt.com web site and it came back say my IIp was 1000kbps and was was downloading at 750k whats going on bt you can check my line my phone num ************
Sage
imjolly
0
this is a public forum I would suggest you delete your phone number before you get some unwanted calls.  remember thsi may also appear on a google search
crispy_roll
0
I'm pretty concerned about this line:
Aren't those values too low?
Sage
john46
They are fine no problems
crispy_roll
0
Update. No improvement at all. I'll try to contact with mods and see what they say.
 Download speedachieved during the test was - 401 Kbps
The throughput of Best Efforts (BE) classes achieved during the test is - 4.97:15.05:80.1 (SBE:NBE:smileytongue:BE)
IceZaroth
0
[ Edited ]
Hiya Crispy, Can i ask you to goto this link below and in there make sure to include a link to this post so the mods can read over and then order your line to be fixed.
Goto:  http://bt.custhelp.com/app/contact_email/c/4951
Link to this Post: http://community.bt.com/t5/BB-Speed-Connection-Issues/Strange-problem-with-broadband-Speed-very-low
Your Line Stats look fine Line Atten is good your close to the exchange your on and your SNR is also fine on the download, In your post can you also ask to have your SNR reset as your upload SNR is 15db it should be around 6db.  It seems like your speed is just stuck and is a minor fix for the MODS.
Once you post on the GOTO link i gave you please allow 48 hours for the Mods to get to you.
Kindest Regards
IceZaroth
BT Community Helper
crispy_roll
0
[ Edited ]
Update.
First, do you always get reply from MODS? Today my connection dropped and after a while it was on again, I found my SN Margin reset to 6.5 and better bandwith 1205 / 19832 but the speed didn't improve at all. It is 24h since I've sent notice to MODS and I will wait another 24h before contacting them again. What really worries me is FEC Errors field in my ADSL Line details. Last time after 4 days it was 245'000, now after 6 hours I have more than 750'000. Is that normal after connection drop? I've checked speed using this speedcheck provided and my profile is still the same, 16000kbs
UPDATE:: 40 minutes past, 35 MB more dowloaded and 100'000 FEC Errors more :/
I paste details below:
DSL Connection
Link Information
Uptime:0 days, 6:01:26
Bandwidth (Up/Down) [kbps/kbps]:1,205 / 19,832
Data Transferred (Sent/Received) [MB/MB]:38.53 / 275.66
Output Power (Up/Down) [dBm]:12.0 / 0.0
SN Margin (Up/Down) [dB]:6.5 / 4.0
Loss of Signal (Local/Remote):1 / 0
Error Seconds (Local/Remote):1 / 0
FEC Errors (Up/Down):0 / 769,697
CRC Errors (Up/Down):0 / 8
HEC Errors (Up/Down):0 / 5
Line Profile:Fast
Moderator
CraigS
0
Hi crispy_roll
Just checked our email inbox and you should get a reply later today :smileyhappy:
Thx
Craig
BTCare Community Mod
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on the left-hand side of the post.
**LIVE CHAT TONIGHT – Join our Infinity Expert chat at 7pm on Tues 15 May**
