Bozwell
0
Wireless connection
Hello,
I wonder whether anyone can help me?
I've just got a new connection and Home Hub 3.
The wireless connection to the hub works fine from my netbook, which is running windows 7 starter.
My problems started when I tried to connected a second, older netbook.  The older netbook runs windows XP.
When I try to set up the wireless connection, I can select the correct SSID (which the computer can "see"), and then the correct wpa-psk key.  When I click on connect, however, the connection fails, and I get a message telling me that the wpa key does not match the SSID.
I know that I have the correct SSID and wpa key, so if anyone could point me in the right direction, I would be grateful.
I have tried disabling the firewall and antivirus.  I have also tried an ethernet connection, which works perfectly.
Thanks,
Gordon
Sage
imjolly
Re: Wireless connection
try changing the wireless in the HH3 to b/g from the default b/g/n
Bozwell
0
Thank for your reply, tried that, no joy.
Sage
john46
hi all I can currently suggest is retry the security code again double checking every character i know you will have tried many times but worth a final try before trying anything else
If you want to say thanks for a helpful answer,please click on the Ratings star on the left-hand side If the reply answers your question then please mark as ’Mark as Accepted Solution’
Expert
geaves
Hi Gordon,
There are a few things I would suggest doing;
Change the wireless setting on the Hub to WPA only.
Go into Control Panel\Network Connections, right click on your wireless connection, select properties, on the second tab, Wireless Networks you'll see a box that says 'Preferred Networks', select yours and delete it.
Now you'll need to find your wireless network card manufacturer, hopefully it's Intel.....connect an Ethernet cable and download the latest driver, Intel have a scan option to scan your machine, install and reboot.
Hopefully when everything comes back up, no Ethernet connection, select View Wireless Network Connection, select yours and enter your key.....and it should connect.
Some older wireless cards have trouble sometimes using WPA especially if you try psk, tkip and all the other options.
Bozwell
Hello all,
Thanks for your help so far.
I have borrowed a usb wireless adapter, which has got the computer connected.  The usb adapter came with software to manage the connections, and that has thrown up the problem with the old adapter; it won't accept WPA keys.
I shall acquire a USB adapter, and call it a draw.
Thanks again,
Gordon
Sage
john46
0
Hi glad to see you have found the problem and a cure thanks for posting back and letting us know if you need any further help please come back and someone will glad to help
