on 19-12-2010 23h37
Are BT Going To Enable Equipment (BT VISION BOX) To Receive The New Freeview HD Channels
Assuming The Vision Box Can Be Upgraded Or Something ......
As The Box Has An HDMI Output "The Connection I Am Using"
Does This Mean Maybe The Box Just Needs Software Upgrade At Some Point/ Or Will BT Provide HD Vision Boxes In The Future....![]()
Solved! Go to Solution.
on 19-12-2010 23h52
The current box doesn't have the hardware to receive HD.
on 19-12-2010 23h52
Freeview HD is transmitted in DVB-T2 format & needs an updated hardware decoder a firmware update will not help. ![]()
Therefore The BT Vision Box needs updating before Freeview HD can be viewed at the full transmitted quality, without upscaling.
on 19-12-2010 23h55
That is what I thought , but when you contact bt they just keep telling people it will HD or No HD that is the real question![]()
on 19-12-2010 23h57
It is capable of downloading and displaying HD Video on Demand, but can't receive over the air transmissions.
on 19-12-2010 23h58
on 03-01-2011 10h50
May be I just turn out of it..
on 02-02-2011 21h59
Well I have given up with BT too - love the films but I just bought a freewiew HD settop box.
on 03-02-2011 7h06
on 03-02-2011 13h03
Guyincognito76 wrote:
I've ashes before, but, would it be theoretically to develop a DVB-T2 adaptor that could plug into the back of the current box?
Yes if you develop a new box which can be aware of the adaptor. Lovely idea, but don't think it's a goer.
