Newbie
Bigbob2011
0
Accepted Solution
Recording on BTvision
If I want to record a programme several days in  advance how do I advance the TV guide a day at a time rather than by half hours. I don't see a +24h or -24h
Expert
masona2
Re: Recording on BTvision
[ Edited ]
Hi and welcome to the forum.
Just press the FF button (>>) on the remote. When in TV guide, this will advance the EPG by 24 hours.
And subsequently another 24 hours with each press. So if you press FF four times, you will advance the EPG by four days.
Edit - Oh, and if you want to go back a day, just press the RWND button (<<).
Hope that helps.
Rank - Mostly Harmless.
Guru
guilbo
[ Edited ]
As Masona, but there is a footnote. >> only works if you use the guide in Grid View, it doesn't work in List.
You can also use the shortcut button on the remote to directly select a day.
Newbie
Bigbob2011
0
Problem solved. Thanks very much.
Newbie
Bigbob2011
0
Thanks for the extra info
