08-02-2011 20h34 - edited 08-02-2011 21h14
My Programme Guide clearly shows Sky Sports 1 and 2, along with the associated programme data. (I assume that this means that I can view these programmes, given that I have the activated vision sports card? My postcode indicates that these may not be available. (I can view Sky Three, Dave, Film4 etc)
I am currently struggling and unable to activate Sky Sports 1 and2, although I have been watching ESPN on the box for years.
The EPG on other (ie not BT Vision) sets also shows the Sky Sports programme as being available.
Solved! Go to Solution.
on 08-02-2011 20h41
on 08-02-2011 20h43
on 08-02-2011 21h07
EPG on other (Sony) sets on same aerial also show Sky Sports. Signal strength on these is v. good.
on 09-02-2011 10h49
No joy after >24H so contacted helpline, waited for advisor who activated my card whilst I operated the TV/Vision box. Do not know why the card was not done automatically - but now all seeems to be fine. Thanks to all who tried to help!
on 09-02-2011 10h53
Why? Because for some bizarre reason in enters a 48 hour automatic set up.
Phoning allows them to bypass the system and get it running.
It sounds a crazy system to me but there you are that's how it is done - I hope there is a reasonable technical explanation for this but I have never heard it.
