on 14-01-2012 3h23
I had auto-login enabled for some time, but suddenly I'm being asked to enter details on each visit to the forums. The auto-login options in My Settings still say, "You can turn off auto-login ...". If I choose to turn it off I get a success message which also says, "To re-enable auto-login, check Remember Password the next time you log in." Trouble is that this option does not appear on my next visit. So it seems that the system still regards me as on auto-login but it isn't doing it.
I can set my computer to remember details, but prefer to enter the site automatically. Is there a general fault, or is it just me?
on 14-01-2012 9h08
Hi Pottyperson,
Thanks for letting us know. I'll see about getting his sorted for you.
Cheers
Craig
on 14-01-2012 19h33
Thanks Craig.
I've made a bit of progress. I normally access the forums via a bookmark to community.bt.com; the login box there does not contain a Remember Password option. But I discovered that the link in community email notifications to community.bt.com/bt/user_subscriptions brings up an option to save login information. Checking that and signing in from there has re-established the auto-login feature which I had lost.
It does seem that something needs fixing, but this will do for now.
Cheers! Alan
on 27-01-2012 10h50
Hi again Craig.
Just to let you know that this problem still exists. I'm finding that out quite regularly because my auto-login setting somehow gets cancelled every few days, requiring me to set it up again each time!
Cheers! Alan
on 28-01-2012 9h29
Hi pottyperson,
The reason this is happening is because the login box on front page does not have a remember me tick box anymore. You may have cleared cookies etc which mean settings to be ‘remembered’ were changed.
The only way to set this back up now is to log in via the login page which can be accessed via the link in KerryG's post here; http://community.bt.com/t5/Forum-Guidance-Ideas/Co
Thx
Craig
on 28-01-2012 9h38 - last edited on 28-01-2012 9h42
Thanks for the explanation Craig. I do clear cookies regularly with CCleaner, which I've set to keep important ones including BT's. I tested this the other day and found that auto-login still worked immediately afterwards. So, whatever is causing the occasional loss of auto-login function, it's not my cookie cleaning.
Never mind, it's but a minor irritation, which I've partly overcome by saving the alternative page as a bookmark.
on 28-01-2012 10h16
CraigS wrote:Hi pottyperson,
The only way to set this back up now is to log in via the login page which can be accessed via the link in KerryG's post here; http://community.bt.com/t5/Forum-Guidance-Ideas/Community-Login/td-p/268959
Thx
Craig
It doesn't always remember it even if cookies aren't deleted.
As mentioned in that link (to a different login page) the implication is that the remember me tick box would be put back on the main page. It's there when you reply to a post and find that you need to login again.
on 01-02-2012 12h26
CraigS wrote:
Hi pottyperson,
Thx
Craig
The login box on the front page has never had a "remember me" checkbox. I usually log in when I respond to a message, which does have it. I too noticed that it wasn't allowing me to stay logged in, so cleared my entire history, cookies and all in case it was that. Didn't help.
on 15-03-2012 8h11
This problem has cropped up again with Google Chrome, my default browser.
I log in to the forums via the screen with the save option. This has been working well enough, usually remembering me for some days. But this week login info has been lost whenever Chrome is closed. I've eliminated the possibility of a cookie issue.
IE9 is fine. In fact, if I sign in with IE the saved info then works for Chrome also.
It's not high priority, but any ideas would be interesting.
on 15-03-2012 8h47
Hi Pottyperson,
No worries, I'll see what i can find out for you ![]()
Cheers
Craig
