I'd like the spell checker not to point out the spelling mistakes in messages I'm quoting.
I'd also like the option to automatically spell check when posting as sometimes I forget, hit post and spot the mistake as it's posting!
+1
(A long post, full of mistakes, that we quote, can be a right pain when we want to check our own reply.....Ignore, Ignore, Ignore, Ignore, Ignore, Ignore, Ignore, Ignore, Ignore, Ignore, Ignore, Ignore, Ignore, Ignore, Ignore, Ignore, Ignore, Ignore, Ignore, Ignore, Ignore, Ignore, Ignore, Ignore, Ignore, Ignore, Ignore, Ignore, Ignore, Ignore, Ignore, gets boring after a while)
Nearly every post i make i always edit because of spelling. It would be fab if it was turned on automatically!
Automatically having your posts spell checked prior to posting would be great. Being able to either ignore quoted text or highlight the text that you would like spell checked would also be great.
An auto-spell check still prompts the user to correct the spelling mistakes, it basically should just be the same as pressing Spell Check currently except that it happens after you've pressed the Post button.
I don't want a spell checker I will make my own mistakes and I get fed up with spell checkers trying to reject English spellings and replace them with USA ones.
Being able to ignore quoted text - good idea
Auto check not so good
as often suggestions are not what was meant - would still like the option to ignore/reject suggestions ![]()
After posting with smileys in I also notice spell check checks smileyindifferent and advises to replace with simple-mindedness! Ironic and very annoying!
You must be a registered user to add a comment on this idea. If you've already registered, please log in. If you haven't registered yet, please register and log in.
Welcome to our Ideas Bank!
This is where we step back and you take the lead. Help us take our community (and more) to a new level by giving us your ideas.
Community members can then promote the best ones to the top and we’ll take it from there by adding the most rated ideas into our community roadmap. We may not be able to build them all but we can certainly try, so get those creative juices going and get posting!
Check out our Ideas Bank FAQs.
