bootjangler
0
Accepted Solution
1471
[ Edited ]
Maybe this isn't the forum for this question, but here goes....
I used 1471 on my landline and the number which had called (10 mins previously), was my own number. Are there are circumstances where this can occur? I hadn't made any calls that day.
plymchris
Re: 1471
Have you got "Call Minder"? I read somewhere that when it calls you, it registers on 1471 as your own number.
Expert
jac_95
Re: 1471
If you receive a text message on your landline your phone rings your number to tell you. Also call minder and other BT call back services will use your number when it rings your landline
cheers,
James
I'm no expert, so please correct me if I'm wrong
Guru
Devon_Dave
Re: 1471
Just to confirm a voice text as well as a 1571 will display (or read back when dialling 1471) the number you have called from, ie your home number.
(If I have helped you in any way to say "Thank You" please click on the star next to the message. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
bootjangler
0
Re: 1471
Yes indeed. Not too much of a modern phone, so no display etc. When I checked, I had a stored message from 10 minutes earlier which was a text from some cold-calling company. Thanks for clearing that up.
