on 18-07-2011 11h37
The keypad on my cordless phone (BT Freestyle 750) suddenly says 'keypad locked' and I cannot get rid of it, or use my phone. I do have another, oldfashioned, phone and have no problems using that.
How can i get back to normal on my cordless? I must have touched the hashkey/lock by mistake.
Marta
Solved! Go to Solution.
on 18-07-2011 12h52
Try holding down the * button ( there should be a small lock symbol beside it ) and it should unlock
on 18-07-2011 16h56
There is no lock symbol by the *key. Doesn't help to hold it down. Any other ideas?
Very grateful for anything that helps.
Marta
on 18-07-2011 17h28
Hi Marta,
have you had a look at the user manual here:
http://btsupport.custhelp.com/ci/fattach/get/20325
Keypad lock is on page 21, it should be just hold it down again.
on 18-07-2011 18h43
on 18-07-2011 18h44
on 03-02-2013 10h03
spent over 3/4 hour on web looking for this answer. It worked. Why is this not in the handbook. thanks for the solution
on 03-02-2013 10h10
It is, on page 21 as mentioned in the earlier post.
BT Broadband customers - help with broadband, WiFi, networking, e-mail and phones.
