Do you mean
Expert
Acceptable levels of FEC and CRC errors
Untill recently my broadband link's been fine and dandy, but I'm not seeing my FEC and CRC errors slowly climbing. Also, interleaving's been applied to my like (Despite me being 300m from the exchange and syncing at 8mbit).
What I want to know is how many FEC/CRC errors should one be experiencing on an average line over (say) a few days uptime.
Re: Acceptable levels of FEC and CRC errors
Hi Welcome to the forums
Here is a basic guide to getting help from the community members done by CL Keith Please read through the link posted http://forumhelp.dyndns.info/speed/first_steps.html
Have you tried the quiet line test? - dial 17070 option 2 - should hear nothing - best done with a corded phone. if cordless phone you may hear a 'dull hum' which is normal
once you have posted the information asked for then the community members can help you more
Thank You
This is a customer to customer self help forum the only BT presence here are the forum moderators
john46 | BT.com Help Site | BT Service Status
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Try a Search
See if someone in the community had the same problem and how they got it resolved.
if you can post the details from your hub stats then we can help further normally interleaving turns on due to line instability FEC's are nothing to worry about as that is just showing interleaving is working but the CRC's should not rise to high
Try a Search
Expert
The connection is still stable and working at regular speed and the line sounds OK (though it has been bucketing it down recently so a connection could be failing on the line intermittently. I was just wondering if the interleaving would switch itself off after a few days or not? I'm not that fussed (I have very few latency dependent apps), I was just thinking if there was a hub stat that would explain why it had been applied?
interleaving is normally automatic but once it comes on it normally stays on the errors shown on your hubstats are what causes interleaving to come on
Try a Search
Expert
Here's my stats (I accidentally unplugged the router the other night, hence the low uptime)
Line state:Connected
Connection time:0 days, 22:29:09
Downstream:7.938 Mbps
Upstream:448 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.1 Annex A
Latency type:Interleaved
Noise margin (Down/Up):17.6 dB / 26.0 dB
Line attenuation (Down/Up):5.6 dB / 2.5 dB
Output power (Down/Up):12.0 dBm / 12.1 dBm
FEC Events (Down/Up):488203 / 13
CRC Events (Down/Up):473 / 7
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
HEC Events (Down/Up):1072 / 8
Error Seconds (Local/Remote):401 / 2
Does that look normal? The line's quet as a mouse.
I would not worry if your download speed is ok
Try a Search
