Do you mean
BT Broadband Desktop Won't Open?
Anyone had this before?  I double click the desktop icon or the ? in the task bar tray and nothin at all happens....even if i left click>Open still nothing?
All I wanna do is set up file sharing?  Is there another way or do i have to use BT BB Desktop?
Any help would be appriciated.
Re: BT Broadband Desktop Won't Open?
Im not to bothered about the Broadband Desktop tool not installing.
Is there another way to set up File sharing between computers connected to my Hub without using the Desktop tool??
Any help much appriciated?
Recognised Expert
You don't have to use BB desktop - in fact I would advise against it.
Could you post what operating system(s) you are using then someone may be able to help.
Oh cool!
Ok I'm operating on Windows XP Profesional Version 2002 Service Pack 3.
Guru
Bin it.
AQ.
"Welcome to Royston Vasey - You'll never leave."
Helpfull lol
Recognised Expert
Here is the Microsoft article on file sharing for XP sp3
http://support.microsoft.com/kb/304040
Distinguished Guru
You can, if you so wish, uninstall BTDHSmiley Happy and then reinstall itSmiley Sad...
Or just go so far to remove itSmiley Wink...
Click start - All programs - BT Broadband Desktop Help - Uninstall (also look in add/remove programs)
Open task manager, check and if found:
remove BTHelpNotifier.exe
remove McciServiceHost.exe
remove McciTrayApp.exe
stop McciCMService.exe in services (control panel - Administrative Tools - Services)
In registry, delete the following (start - Run - Regedit)
HKEY_LOCAL_MACHINE\SOFTWARE\Motive
HKEY_CURRENT_USER\Software\Motive
Restart your PC - Stop here if you don't want to reinstall or download it again -
http://bt.custhelp.com/app/answers/detail/a_id/12941/~/bt-broadband-desktop-help
FYI, if you do decide to keep it off your PC/Laptop you may want to read this?
(only if you don't reinstall!!Smiley Indifferent)
http://community.bt.com/t5/BB-in-Home/Broadband-Desktop-Help-automatic-data-collection/m-p/56566#M35...
-+-No longer a forum member-+-
Cheers guys. sorted,
