Do you mean
0
Accepted Solution
BT Dongle
We have a PC which seems to have a dodgy ethernet connection so it seemed a good idea to bring the BT Dongle into service which we have not really used.  Unfortunately it would only find the ethernet and not the wifi.  It was about 10 feet from the HomeHub whereas laptops which were 20-30  feet away and through brick walls worked perfectly.
Has anyone any ideas?
Malcolm
Re: BT Dongle
If its the mobile dongle, then that does not receive WiFi, only GPRS, and 3G mobile signals.
0
Re: BT Dongle
[ Edited ]
Thank you Keith for your reply.
It is the dongle that has the Connection Manager showing wifi, mobile and ethernet sources.  We bought it to connect to wifi hotspots at motorway service stations etc.  We have had a bit of trouble with connections in the house and were trying to see if the dongle made any difference, but it would only find ethernet, not even a mobile signal.
Malcolm
Re: BT Dongle
that type of dongle need a 3g mobile phone signal it will not work in conjunction with your hub two totally different technologies i am sorry to say
john46 | BT.com Help Site | BT Service Status
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Try a Search
See if someone in the community had the same problem and how they got it resolved.
Guru
Re: BT Dongle
Malcolm
I think this is the type of USB wi fi adapter that you need:
http://www.ebuyer.com/232655-edimax-wifi-300mbps-usb2-adapter-ew-7718un?utm_source=google&utm_medium...
I have not used it and am not recommending it.
toekneem
(EASBF)
Re: BT Dongle
The BT Connection manager is misleading. It simply manages existing connections, if they do not exist within the computer/laptop, it has no way of knowing.
You are not the first person to be mislead.
Provided your SIM card is activated, the mobile BB normally works, but many people fail to do this, as it involves logging into BT and creating an account, and is a bit complicated.
0
Re: BT Dongle
Thank you all for your replies.
It certainly is not clear what BT Dongle is designed to do. Another gem to drop into the pool of experience. The Edimax product looks more the part. However, it dawned on me over Christmas that this problem had appeared rather suddenly so it could be that on of MS's regular updates had mended it worse, so I downloaded a new driver and all is back to normal.
Thanks again for all your help.
Malcolm
0
Re: BT Dongle
Hi that is good new just shows the importance of regular updates being necessary
Try a Search
