Do you mean
BT Help - cannot access health check
BT Help
When I access Help I go directly into a broadband connection process which checks my connection which is ok
I used to be able to access a health check which gave me the option to check the history and fix issues.  Been doing this for two years.  I use McAfee installed on the computer by Dell when I purchased it over a year ago.  Never any problem.
This no longer appears
I have removed the "help" and then reinstalled it - still no difference.
Have BT removed the health check facility   ???
Re: BT Help - cannot access health check
I would suggest uninstalling Desk top help then reinstalling it although many here recommend not using the programme as it can cause more problems then it solves however that has to be your choice
john46 | BT.com Help Site | BT Service Status
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Try a Search
See if someone in the community had the same problem and how they got it resolved.
As  I previously stated I have already done what you have suggested to no avail.
then i would suggest that you just uninstall it and forget it
Try a Search
