Do you mean
0
BT HomeHub 2 keeps disconnecting and reconnecting to broadband?
So I've had the router for a few years now and never really had many problems with it. But recently it has been occasionally disconnecting from the internet for about a minute or so then reconnecting, the broadband light goes a flickering orange then back to solid blue after about a minute. I've never had this problem before and it has only started happening since a few days ago.
Could anyone help me find a solution to this problem?
Thanks.
Guru
0
Re: BT HomeHub 2 keeps disconnecting and reconnecting to broadband?
Hi,
Have you tried the test socket? Located behind master socket removable bottom faceplate (see picture)
if you have connection at the moment then, To enable us to look into your Broadband Problem, please follow below:
1) are you conneted to the master socket or test socket?
2) can your post your BT Speedtest results by using http://speedtester.bt.com (not beta version) [best done with a wired connection ie ethernet]
3) Have you tried a quite line test. Dial 17070 option2 from landline, there should be no distinctive noise but slight 'dull' hum normal on cordless phones
4) can you post your adsl line statistics
ADSL Line Stats Help
If you have a BT Home Hub like the one below...
Then:
1) Go to http://192.168.1.254 or http://bthomehub.home
2) click Settings
3) Click Advanced Settings
4) Click Broadband
5) Click Connection or sometimes called ADSL (see picture Below)
The direct Address is http://bthomehub.home/index.cgi?active_page=9116 (for bthomehub3)
cheers
jac_95 | BT.com Help Site | BT Service Status
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Try a Search
See if someone in the community had the same problem and how they got it resolved.
0
1) I think I'm using test socket.
2)1. Best Effort Test: -provides background information.
 Download  Speed
 3.49 Mbps
0 Mbps4 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 3.49 Mbps
 For your connection, the acceptable range of speeds is 1.2 Mbps-4 Mbps.
 IP Profile for your line is - 4 Mbps
2. Upstream Test: -provides background information.
 Upload Speed
 0.62 Mbps
0 Mbps0.83 Mbps
Upload speed achieved during the test was - 0.62Mbps
 Additional Information:
 Upstream Rate IP profile on your line is - 0.83 Mbps
3)Yeah there's no noise at all really.
ADSL line status
Connection information
Line stateConnected
Connection time0 days, 0:36:05
Downstream4,539 Kbps
Upstream793 Kbps
ADSL settings
VPI/VCI0/38
TypePPPoA
ModulationITU-T G.992.5
Latency typeInterleaved
Noise margin (Down/Up)6.7 dB / 11.1 dB
Line attenuation (Down/Up)39.0 dB / 22.8 dB
Output power (Down/Up)0.0 dBm / 12.8 dBm
Guru
0
[ Edited ]
thanks,
sorry can you post your Adsl line statistics agian as there is a few missing. You may need to click "More Details" .
Is there any noise on the quite line test?
cheers
Try a Search
0
There is no noise in the line test.  ADSL line status
Line stateConnected
Connection time0 days, 0:50:27
Upstream793 Kbps
ADSL settings
VPI/VCI0/38
TypePPPoA
Noise margin (Down/Up)6.6 dB / 8.0 dB
Loss of Framing (Local)12
Loss of Signal (Local)1
Loss of Power (Local)0
FEC Errors (Down/Up)9424 / 4294967051
CRC Errors (Down/Up)4 / N/A
HEC Errors (Down/Up)
N/A / 0
Error Seconds (Local)4
Guru
0
your noise margin is ok, but your sync rate is still poor for your Line attenuation. For your line length (approx. 2.8km) I would have estimated a sync rate at around 9000-9568kbps on ADSL2+ for a good line.
Is it possible to stay connected in test socket for a few hours and see if it can maintain a connection.
cheers
Try a Search
0
is your hub connected to the test socket as shown in jac_95's post if not can you please try and connect there this will eliminate any internal wiring problems
john46 | BT.com Help Site | BT Service Status
Try a Search
Newbie
0
Hi
I know this is an old post, but did you get anywhere with this?
I have a similar problem but can't decide whether it is a physical issue (rainy days..) or when my Outlook IMAP connection is generating a lot of traffic to external (gmail) email servers.
Just wondering if BT have an undocumented "spambot" limiting cutoff somewhere. If I run Outlook regularly, then no problem. I f I don't connect for a few days then hey presto, every mail sync causes a disconnection...
Your feedback would be really good to hear.
Alex.
0
There are known problems with the home hub 2.
Reported problems with the Home Hub 2.0
If the home hub is restarting on its own, then that may be the reason.
