Do you mean
Newbie
BT Homehub
Whenever I try to go to my homehub settings using either 192.168.1.254 or bthomehub.home I get a red triangle with an explanation mark in it and a message telling me that no more than 100 sessions at a time are allowed. Whats wrong?
Distinguished Guru
Re: BT Homehub
Hi
Never had that one before, you may have to power down and then power up the HH, If that does not work you may need to do a factory reset.
(If I have helped you in any way to say "Thank You" please click on the star next to the message. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Newbie
Re: BT Homehub
A reset did the trick. Thanks
