Do you mean
0
Accepted Solution
BT Yahoo Home Page
Cannot get BT Home Page using XP. Keep getting Yahoo sign in not BT. Works O.K. from Vista. Is anyone else having this problem?
0
Re: BT Yahoo Home Page
are you using IE if so which version?  have you tries a different browser - firefox, chrome
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on left hand side.
0
Hi Welcome to the forums
Yahoo page working ok here
john46 | BT.com Help Site | BT Service Status
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Try a Search
See if someone in the community had the same problem and how they got it resolved.
0
Using IE8. Haven't tried any other browser. Has worked perfectly well for last few years up until midday today.
0
I use IE9 and don't have any problems with the BTYAHOO homepage.  you could try IE9 if you have  vista or windows 7 or try firefox and see if there is still a problem
0
 mentioned in my original posting, I can access via Vista using my laptop, but only get Yahoo sign in when using P.C.
0
sorry what I said was that provided your pc has vista or windows 7 then you could upgrade your IE8 to IE9 or you could try a different browser such as firefox
0
Thanks for your time and help, have now discovered that my neighbours have been having same problem with XP. However have just tried again and it's now working O.K. Must have been some local problem as neighbour has just said his is O.K. as well!
