Do you mean
Broadband and Windows XP
I have a BT home Hub and my broadband connects automatically on my Windows Vista laptop which the broadband was set up with. However, the laptop with windows XP on which has a wireless network connection recognises the BT home Hub and says it should connect automatically but it doesn't. If I try and connect manually it tries to connect but nothing happens. It has the correct network key details. Does anyone have suggestions please?
Recognised Expert
Re: Broadband and Windows XP
You may find some helpful information Here
"I have this awful feeling someone is watching every move I make (one of my pet hates is router location tagging)." Marvin (A paranoid Android)
Thanks for your suggestion. I have tried that, but it makes no difference.
Recognised Expert
It's difficult to advise with so little information, setups vary with Homehub Versions & browsers.
Some default Homehub Wifi setup information can be found here
Strong WPA passphrases can be found here: https://www.grc.com/passwords.htm
Hello Janet,
Just a few more details please:
Has the laptop ever worked with this hub if so when, if not has it worked recently with any other wireless router.
What make is the laptop, some manufacturers install their own wireless connection software etc.
What exactly happens when you try to connect.
Hi
I am just off the phoen with BT tech support. They tell me that Hub 6 is NOT COMPATIBLE with Windows XP.
No-one told me before I returned hub 5 which did work with  XP. Over 10% of users are still on XP, so this status is unacceptable.
as you are running windows XP which is a very old windows version did you ask if hub was compatible before getting it as even microsoft stopped supporting XP in 2014
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on left hand side.
Duplicate post here https://community.bt.com/t5/Connected-Devices-Other/Unable-to-connect-to-new-Hub-6/m-p/1799415#M1468...
Forumhelp (Private website) Lots of additional information for BT Residential Broadband connections only.
