Do you mean
Newbie
0
Broadband keeps disconnecting
My BT broadband keeps disconnecting, it has been happening every now and then for a few days but now its getting worse and worse, tonight it feels like every couple of mins. Ive connected the router directly into the master socket now with no other equipment attached and the problem hasn't improved.
Figures from the home hub are below. The noise margin keeps going up and down constantly between about 6dB and 10dB.
Does anyone have any idea what I can do to sort this, its getting quite anoying.
ADSL line status
Connection information
Line stateConnected
Connection time0 days, 0:14:17
Downstream7,616 Kbps
Upstream448 Kbps
ADSL settings
VPI/VCI0/38
TypePPPoA
ModulationITU-T G.992.1
Latency typeInterleaved
Noise margin (Down/Up)7.7 dB / 19.0 dB
Line attenuation (Down/Up)26.0 dB / 16.0 dB
Output power (Down/Up)19.7 dBm / 11.9 dBm
Loss of Framing (Local)13
Loss of Signal (Local)25
Loss of Power (Local)0
FEC Errors (Down/Up)70415 / 0
CRC Errors (Down/Up)83 / N/A
HEC Errors (Down/Up)N/A / 0
Error Seconds (Local)3
21:49:43  28 JunxDSL linestate up (ITU-T G.992.1; downstream: 7616 kbit/s, upstream: 448 kbit/s; output Power Down: 19.7 dBm, Up: 11.9 dBm; line Attenuation Down: 26.0 dB, Up: 16.0 dB; snr Margin Down: 19.0 dB, Up: 11.1 dB)
21:49:23  28 JunxDSL linestate down
21:48:48  28 JunxDSL linestate up (ITU-T G.992.1; downstream: 7520 kbit/s, upstream: 448 kbit/s; output Power Down: 19.7 dBm, Up: 11.9 dBm; line Attenuation Down: 26.0 dB, Up: 16.0 dB; snr Margin Down: 17.0 dB, Up: 5.9 dB)
21:48:35  28 JunxDSL linestate down
21:23:19  28 JunxDSL linestate up (ITU-T G.992.1; downstream: 7616 kbit/s, upstream: 448 kbit/s; output Power Down: 19.7 dBm, Up: 11.9 dBm; line Attenuation Down: 26.0 dB, Up: 16.0 dB; snr Margin Down: 23.0 dB, Up: 11.0 dB)
21:23:03  28 JunxDSL linestate down
21:20:01  28 JunPPP link up (Internet) [86.133.5.137]
21:20:01  28 JunPPP CHAP Chap receive success : authentication ok
21:20:00  28 JunPPP CHAP Receive challenge (rhost = ERX18.Birmingham4)
21:19:54  28 JunxDSL linestate up (ITU-T G.992.1; downstream: 7616 kbit/s, upstream: 448 kbit/s; output Power Down: 19.7 dBm, Up: 11.9 dBm; line Attenuation Down: 25.0 dB, Up: 16.0 dB; snr Margin Down: 22.0 dB, Up: 10.9 dB)
21:19:42  28 JunxDSL linestate down
21:19:27  28 JunPPP link down (Internet) [86.133.5.137]
21:19:09  28 JunxDSL linestate up (ITU-T G.992.1; downstream: 7616 kbit/s, upstream: 448 kbit/s; output Power Down: 19.7 dBm, Up: 11.9 dBm; line Attenuation Down: 26.0 dB, Up: 16.0 dB; snr Margin Down: 20.0 dB, Up: 10.9 dB)
21:18:52  28 JunxDSL linestate down
21:18:20  28 JunxDSL linestate up (ITU-T G.992.1; downstream: 7616 kbit/s, upstream: 448 kbit/s; output Power Down: 19.7 dBm, Up: 11.9 dBm; line Attenuation Down: 26.0 dB, Up: 16.0 dB; snr Margin Down: 20.0 dB, Up: 10.6 dB)
21:18:08  28 JunxDSL linestate down
21:15:57  28 JunxDSL linestate up (ITU-T G.992.1; downstream: 7616 kbit/s, upstream: 448 kbit/s; output Power Down: 19.7 dBm, Up: 11.9 dBm; line Attenuation Down: 26.0 dB, Up: 17.0 dB; snr Margin Down: 12.0 dB, Up: 9.3 dB)
21:15:41  28 JunxDSL linestate down
21:04:26  28 JunxDSL linestate up (ITU-T G.992.1; downstream: 7616 kbit/s, upstream: 448 kbit/s; output Power Down: 19.8 dBm, Up: 11.9 dBm; line Attenuation Down: 26.0 dB, Up: 16.0 dB; snr Margin Down: 22.0 dB, Up: 10.9 dB)
21:04:14  28 JunxDSL linestate down
20:54:23  28 JunxDSL linestate up (ITU-T G.992.1; downstream: 7616 kbit/s, upstream: 448 kbit/s; output Power Down: 19.7 dBm, Up: 11.9 dBm; line Attenuation Down: 26.0 dB, Up: 17.0 dB; snr Margin Down: 10.0 dB, Up: 8.8 dB)
20:54:11  28 JunxDSL linestate down
01:03:53   1 JanxDSL linestate up (ITU-T G.992.1; downstream: 7616 kbit/s, upstream: 448 kbit/s; output Power Down: 19.7 dBm, Up: 11.9 dBm; line Attenuation Down: 26.0 dB, Up: 17.0 dB; snr Margin Down: 12.0 dB, Up: 9.8 dB)
0
Re: Broadband keeps disconnecting
Hi Welcome to the forums
Here are some help pages done by CL Keith http://forumhelp.dyndns.org/speed/Speed.html
Can you also post the full results from BT Speedtest speedtester.bt.com
Have you tried connecting to the test socket at the rear of the master socket  Test Socket.jpg
Have you tried the quiet line test? - dial 17070 option 2 - should hear nothing - best done with a corded phone. if cordless phone you may hear a 'dull hum' which is normal
This is a customer to customer self help forum the only BT presence here are the forum moderators
john46 | BT.com Help Site | BT Service Status
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Try a Search
See if someone in the community had the same problem and how they got it resolved.
Newbie
0
Test socket makes no difference.
Speed test results:
Download speed achieved during the test was - 5.97 Mbps
For your connection, the acceptable range of speeds is 0.6 Mbps-7.15 Mbps
Additional Information: Your DSL Connection Rate :7.62 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
IP Profile for your line is - 6.5 Mbps
I only have access to a cordless phone and the quiet line test seems to have some noise that comes and goes. Almost sounds like an old radio with bad reception if that makes sense.
0
hi the quiet line test should be totally silent when using a cordless phone just a dull hum should be heard you need to report that to BT Faults on 151 but do not mention broadband in the call once the noise is cured your broadband will improve
Try a Search
0
did you try the quiet line test from the test socket just in case the noise was from your internal wiring?
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on left hand side.
