Do you mean
DMG
0
Re: Broadband speed suddenly very slow
Is there anything I can do about my noise margin or is this something that BT need to correct?
DMG
0
I've rechecked my router stats this morning as well:
System Up Time 13:27:55
PortStatusTxPktsRxPktsCollisionsTx B/sRx B/sUp Time
WANPPPoA7798623501227608:41:57
LAN10M/100M90692800440188751213:27:50
WLAN11M/54M183851858703175313:27:40
ADSL LinkDownstreamUpstream
Connection Speed8180 kbps1120 kbps
Line Attenuation42 db13.5 db
Noise Margin3 db6 db
Recognised Expert
0
Do you by any chance use the DGTEAM firmware on your Netgear and alter the SNR margin?
0
your internet connection uptime is only 8min and speed has improved but as I said I thought you might have a problem with a low margin.
I run on  a margin of about 2.2/2.4 so you can run on a margin of 3 if your line is good
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on left hand side.
DMG
0
An update on my BT situation - I got home on Friday night and checked my router stats - not looking good!  I then found out that my phone line had died!  I've raised the fault with BT and it appears to be an exchange issue, so I am hoping they will be out to fix it shortly.  I still have limited (slow) internet connection but no phone line...
WANPPPoA242523520817400200:08:42
LAN10M/100M3353334604427105500:09:29
WLAN11M/54M1730064000:09:19
Connection Speed1400 kbps655 kbps
Line Attenuation57 db24 db
Noise Margin3 db5 db
Recognised Expert
0
That suggests theres a break in one of the wires.  You see as broadband only needs one wire to connect whereas the telephony needs two.  Have you tried unscrewing all the sockets, extensions and masters in the house and checking for the slightest break in any of the wires as far as you can see?
