Do you mean
Newbie
0
Accepted Solution
CAN I CHANGE MY PASSWORD ON MY HOME HUB
Hia does anyone know of any way i can control the kids usage on the wireless home hub.  We have a time restriction in place that the kids cant use the internet after 9pm but i think they are sneaking on it, we have to keep the internet on for our own use but this means they can still get access is there any way I can make the home hub restricted use at certain times? Thanks a lot xx
Recognised Expert
0
Re: CAN I CHANGE MY PASSWORD ON MY HOME HUB
[ Edited ]
Enter
192.168.1.254 in browser click A to Z top right
then ADMIN PASSWORD CHANGE under A in list and change it
but don't forget it and make sure they are not looking over your shoulder
If any post helps tick the star box on the left
Just cause Im paranoid dont mean they are not out to get me
0
You don't mention what HHub you have , on my HHub2 I can use settings in the HHub Manager to restrict device access.settings.PNG
0
[ Edited ]
Edited. Beaten to it Smiley Happy
Recognised Expert
0
Confused title says CHANGE PASSWORD
Content sseems to ask  Can the kids be kept off after 9  but the net left on  for your use
Newbie
0
Hia and thanks for your replies, we have the bt home hub 2 but unsure how to get onto the home hub control that you showed on the message that looks like exactly what i need to control the use of the kids computers.  Where do i start to open up the home hub control on my computer?
Thanks also for help with changing password i will probably do that tonight while i try and work out the other way of doing it, thanks kazzie
Recognised Expert
0
[ Edited ]
Enter
then  under P look for PARENTAL CONTROL
you will need your hub pass word
0
[ Edited ]
Yes you can by changing admin password. To change the admin password on BT home hub 5 open the hub by clicking on the link http://bthomehub.home and  follow the steps mentioned below:
-Select “Settings”.
-Enter your current admin password and select the “Admin Password” menu.
-Enter your new admin password twice. You can also setup a security question which will help you in retrieving the password when you forget it.
-After setting the security question, click on “Change Password”.
If you are not successful in your attempt you must call BT Customer Service.
0
@cherrie
where are you digging up these old posts?  this one is over 5 years old and the HH5 was not even out then
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on left hand side.
0
The post is also marked as solved by the poster
john46 | BT.com Help Site | BT Service Status
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Try a Search
See if someone in the community had the same problem and how they got it resolved.
