Do you mean
Can BT reset a Home Hub 3 remotely?
[ Edited ]
Re: Can BT reset a Home Hub 3 remotely?
your exchange can re-sync your hub/router so answer would be yes.
BT can get access to your router whenever it is connected to the internet.
So yes they can reset it and do a whole lot more.
Psi
Erlidoch 'm namyn ewyllysi erioed arhosa 'm
