Do you mean
Accepted Solution
Connecting my mobile to my new BT hub
Can anyone tell me if I can connect my mobile phone to my BT hub?  If yes, how do I do it?  My mobile contract is with 3 if that makes a difference.
Distinguished Guru
Re: Connecting my mobile to my new BT hub
Hi and welcome.
What is the make and model of your phone? You could only connect it if the phone has wifi capabilites.
(If I have helped you in any way to say "Thank You" please click on the star next to the message. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
if your phone has wifi capabilities then follow this  http://community.bt.com/t5/BB-Out-About/any-news-on-voip-for-touch2-hero/m-p/12877#M1192
I have set up my desire without any problem
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on left hand side.
My phone is a LG GT405.  I do have internet access via my 3 contract, but wondered if I could also utilise my bt hub as the signal strength where I live via my phone is hopeless!
you need wifi acces not 3g and don't think your phone has wifi
Sorry your phone does not have wifi so no chance of connecting wireless
john46 | BT.com Help Site | BT Service Status
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Try a Search
See if someone in the community had the same problem and how they got it resolved.
Thank you for that information.
