Do you mean
0
Accepted Solution
Could I get interveled permanently off
My line type was changed today, and I know it was changed because my line was becoming unstable, but I would like to have it permanently off because it has decreased my speed and has completely stopped me from playing online games without interruptions. Thank you
Distinguished Guru
Re: Could I get interveled permanently off
Yes you can. Call the help desk and request it off. As you know it may make your line unstable which can be just as bad for gaming.
0
Ok, may I have the number for the help desk please?
Distinguished Guru
08001114567
0
Thank you very much, is it possible that the mods could chage the line type too?
Distinguished Guru
They could but it takes about 72 hours for them to get back to you. Interleaving would then be turned off the next working day from the time the order was submitted so it may be quicker to call up.
0
Ok, thank you very much for your help
0
if your line is as unstable as you say then switching to fast will make it even worse - you were on fast at end of last month so line must have been dropping for it to change to interleaved - still your choice
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on left hand side.
0
I had a perfectly stable Fast profile on my ADSL line a while ago and overnight it lost about 4meg, checked the router and it had dropped to Interleave error correction profile, there was 0 wrong with Fast at all, it was not unstable, when talking to the technicians they said a problem with the exchanged had dropped the profile
I was only a week or so away from Infinity so just waited for that instead, but just to point out there is not always an unstable problem on the line that causes Interleaving to be switched on
Personally I would prefer fast unstable than the joke that is interleaved
0
@Detection this post has been marked as solved by the OP
john46 | BT.com Help Site | BT Service Status
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Try a Search
See if someone in the community had the same problem and how they got it resolved.
