Do you mean
Expert
0
Accepted Solution
DNS server returns IP addresses even for domain names which should not resolve.
Like a number of other people I have been looking at the BT Broadband service and have found that there is an issue with the current DNS server. What I / we have found is that the DNS server returns IP addresses even for domain names which should not resolve. See following -
DNS results wildcarding (?): Warning
Your ISP's DNS server returns IP addresses even for domain names which should not resolve. Instead of an error, the DNS server returns an address of 92.242.132.15, which resolves to unallocated.barefruit.co.uk.
There are several possible explanations for this behavior. The most likely cause is that the ISP is attempting to profit from customer's typos by presenting advertisements in response to bad requests, but it could also be due to an error or misconfiguration in the DNS server.
The big problem with this behavior is that it can potentially break any network application which relies on DNS properly returning an error when a name does not exist.
The following lists your DNS server's behavior in more detail.
  • www.{random}.com is mapped to 92.242.132.15.
  • www.{random}.org is mapped to 92.242.132.15.
  • fubar.{random}.com is mapped to 92.242.132.15.
  • www.yahoo.cmo [sic] is mapped to 92.242.132.15.
  • nxdomain.{random}.netalyzr.icsi.berkeley.edu is mapped to 92.242.132.15.
Moderators could you please investigate this for us.
Infinidim
Megadodo Publications
Ursa Minor Beta
If you want to say thanks for a helpful answer, please click on the Ratings star on the left-hand side
If the the reply answers your question then please mark as ’Mark as Accepted Solution’
Distinguished Guru
0
Re: DNS server returns IP addresses even for domain names which should not resolve.
They have been doing this for months.
If you type a random address into your web browser, you will probably find that you get a web page, rather than just an error message.  That page will have an opt-out link on it.  Once opted out, the change should be permanent.
0
[ Edited ]
BT use a Barefruit (which your post seems to suggest) service called 'Error Resolution'.
http://www.barefruit.com/background/error_resolution.php
Any DNS that can not get resolved goes via this service and returns a page showing paid adverts and/or links related to what they think you were looking for.
BT refer to this as 'BT Web Address Help' and can be turned off on an opt-out basis via this link: http://preferences.webaddresshelp.bt.com/selfcare/
I assume BT's view is this helps improve the user experience and provides some directed help instead of a blank error page.
Further details: http://www.bt.com/help/webaddresshelp
Expert
0
[ Edited ]
Thanks for this RedAmberGreen.
Infinidim
Ursa Minor Beta
0
I too would like the DNS to return unresolved domains correctly, and not hi-jack typos.
I followed the link and ended up at http://preferences.webaddresshelp.bt.com/selfcare/preferences.cgi
With a message of:
BT Web Address Help - Preferences
Sorry. Unfortunately we have encountered an error and have been unable to check your Web Address Help preferences.
Is this just a temporary error, or have BT moved the preferences page and made all the old links invalid?
