Do you mean
0
Re: Disapointed with broadband upstream and downstream speed
if your exchange is 21CN enabled then you can try uk sales 08007830056 and as a new customer complain about being on adslmax when your exchange is 21CN enabled - why are you not on adsl2/2+?
if you get no help from sales then email the mods and see if they can get you sorted and on to adsl2/2+  http://bt.custhelp.com/app/contact_email/c/4951
mods can take upt o 3 days to reply to you
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on left hand side.
0
Right, got telnet access enabled and issued
adsl info --stats and got....
~ # adsl info --stats
adsl: ADSL driver and PHY status
Status: Showtime
Last Retrain Reason: 0
Last initialization procedure status: 0
Max: Upstream rate = 1224 Kbps, Downstream rate = 10060 Kbps
Channel: INTR, Upstream rate = 448 Kbps, Downstream rate = 8128 Kbps
Link Power State: L0
Mode: G.DMT
TPS-TC: ATM Mode
Trellis: ON
Line Status: No Defect
Training Status: Showtime
Down Up
SNR (dB): 7.9 25.0
Attn(dB): 27.5 14.5
Pwr(dBm): 19.7 12.3
G.dmt framing
K: 255(0) 15
R: 20 16
S: 1.0000 8.0000
D: 64 4
As its reporting the Mode to be G.DTM this validate that I've got an ADSL Max connection on G.992.1 right?
yes and confirmed by speeds 8128/448
0
Hi its a matter of following imjolly's advice and getting moved to adsl2+ try UK sales if no luck the contact the mods
john46 | BT.com Help Site | BT Service Status
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Try a Search
See if someone in the community had the same problem and how they got it resolved.
0
So after quite a long time on the phone I've managed to get my profile changed.
adsl info now :
Status: Showtime
Last Retrain Reason: 8000
Max: Upstream rate = 1208 Kbps, Downstream rate = 15448 Kbps
Bearer: 0, Upstream rate = 1215 Kbps, Downstream rate = 13951 Kbps
Mode: ADSL2+
TPS-TC: ATM Mode
Trellis: USmiley SurprisedN /DSmiley SurprisedN
Down Up
SNR (dB): 6.1 5.9
Attn(dB): 31.5 12.9
Pwr(dBm): 0.0 12.5
However something odd seems to have happened with the noise / attenuation on the line.
Previously ::
SNR (dB): 7.9 25.0
Attn(dB): 27.5 14.5
Pwr(dBm): 19.7 12.3
Now ::
SNR (dB): 6.1 5.9
Attn(dB): 31.5 12.9
Pwr(dBm): 0.0 12.5
I wouldn't have expected these to change significantly. Is this something to be concerned about? SNR has dropped and Attenuation has increased. The Power reporting as 0 is a little on the odd side also!
0
stats looking ok and now adsl2+
noise margin is about normal of 6, attenuation normally increases by 2/3 db on 21CN and the 0 power is ok and a reporting fault
0
hi no the snr is now at the default setting and it is normal for attenuation to increase by 2to 3 dB when going to adsl2+ power reporting is a software bug that pops up occasionally nothing to worry about just remember you are on a 10 day line training time again so leave the router with no manual restarts however you may get the odd disconnection while the line stabilises its best speed
Try a Search
