Do you mean
Re: Download Speed Decreased.... Again :(
I totally agree in the changing provider . I have had no problems ever up untill last sunday always been fine but now my downloads is 0.3kbps   come on ya having a laff . my 3g is faster on my phone . Had engineer out said every thing ok here and exchange. Its higher up who supply bt . Any way bt said tuesday mine going to be sorted by ,i bet you its not and i told the nice women at bt if its not i will cancel !! contract or not as this is not what i signed up for and it will be cancelled i promise that ......
i dont want the hassle of changing suppler but i need broadband for my work not dial up .. then again dial up is faster than this ..  i will be getting in touch with ofcom as this is not acceptable and theres a lot in the same situation but bt will still want full money for this string and 2 bake bean tin internet .........
Some thing needs to be sorted
SKYS DOING SOME GOOD DEALS AND ON LINE RENTAL !!!!!!...........  HMMMMMMMMMMMMMMMMM Smiley Wink
Guru
So you have no extensions.
And your old BT socket is split into 2 parts? .... broadband and phone?
I take it , it's not the new type of SSFP .... adsl v1.
Gaz quick help note ofcom are really just a advise service now,but they will take your details and give you a ref number which gets added to there lists the ones you need are Otelo link below.Good luck!
http://www.otelo.org.uk/pages/1home.php
Yeah I have reallly old one, this is mine.
Like I said I live in a real old house that has been converted into a flat
Okay a little update and things are looking up, my router restarted itself last night while I was sleeping.
Here are the current stats.
ADSL line status
Connection Information
Line stateConnected
Connection time0 days, 07:48:48
Downstream8,125 Kbps
Upstream448 Kbps
ADSL Settings
VPI/VCI0/38
TypePPPoA
ModulationG.992.5 Annex A
Latency typeInterleaved
Noise margin (Down/Up)16.6 dB / 21.0 dB
Line attenuation (Down/Up)33.5 dB / 16.4 dB
Output power (Down/Up)15.8 dBm / 1.5 dBm
Loss of Framing (Local/Remote)0 / 0
Loss of Signal (Local/Remote)0 / 0
Loss of Power (Local/Remote)0 / 0
FEC Errors (Down/Up)193 / 1
CRC Errors (Down/Up)3 / 1994
HEC Errors (Down/Up)4 / 0
Error Seconds (Local/Remote)2 / 191
Test1 comprises of two tests
1. Best Effort Test: -provides background information.
Download Speed
273 Kbps
0 Kbps500 Kbps
Max Achievable Speed
 Download speedachieved during the test was - 273 Kbps
 For your connection, the acceptable range of speedsis 100-500 Kbps.
 Additional Information:
 Your DSL Connection Rate :8124 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
 IP Profile for your line is - 350 Kbps
The throughput of Best Efforts (BE) classes achieved during the test is - 19.14:28.9:51.95 (SBE:NBESmiley TongueBE)
These figures represent the ratio while sententiously passing Sub BE, Normal BE and Priority BE marked traffic.
The results of this test will vary depending on the way your ISP has decided to use these traffic classes.
2. Upstream Test: -provides background information.
Upload Speed
360 Kbps
0 Kbps448 Kbps
>Upload speed achieved during the test was - 360 Kbps
 Upstream Rate IP profile on your line is - 448 Kbps
And the speedteest hasn't changed yet
So I've got my speeds back, but I assume I have to give my profile time to catch up?
How long would it take for my ip profile to catch up? Still getting 0.34mbps with the speedtest
Expert
Three days max. Has it gone back up yet?
If my answer was helpful, please give me a star by clicking the star on the left hand side.
Thank you.
3 days appeared to be the standard for adslmax but from personal experience it appears that adsl2+ can take 5/6 days sometimes longer before updating
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on left hand side.
