Do you mean
0
Accepted Solution
Facebook connection problems
I've been having intermittent problems connecting to Facebook today - and isn't the Facebook server we get a mirror within the BT network, presumably to save load? I am guessing so because when I do a traceroute the server ends in ash2.facebook.com, which I presume means it's in Ashford. I get a blank page, or it times out. And then after a few minutes it's fine, and it's fine for a while, until it goes again.
0
Re: Facebook connection problems
It's just been glitchy over the past 24 hours
0
Now it seems to be lagging a couple of hours behind. I get an email notification that someone's commented on my status, or replied to my comment, and when I click the link it's not there, and it doesn't show up for a couple of hours. This has happened a few times today.
0
this problem is solved by replacing http://www.facebook.com/whatever with https:/ssl.facebook.com/whatever
Newbie
0
The solution is go to https://ssl.facebook.com/   whatever
But why  has the problem apparently only arisen with BT?
0
another solution is to use another DNS server as BTs DNS is not resolving the HTTP addy.
Expert
0
facebook
Cannot get onto it, is there something wrong with my machine if so how do I get around it?  Can get onto most of my usual sites I use except facebook
0
Re: facebook
Down for me as well, also another site I frequent. Looks like a routing issue as I can access via my mobile phone on 3.
0
Re: facebook
I cant access it either
Expert
0
Re: facebook
just tried it again no luck yet my brother who uses a different web provider can.  Can ping it and trace route it yet nothing through IE or firefox so something wrong with BT
