Do you mean
Frequent DCs
Hi,
We have been experience frequent DC's in the last 10 days.
I was aware our exchange was being upgraded / looked at on the 10th of June.
Is anybody available to help? Paddy helped with the last closure of another issue about 10 days ago also.
Thanks,
CT
Re: Frequent DCs
Have you tried the quiet line test dial 17070 option 2 you should hear no noise if you can hear noise then it needs reporting to BT faults on 151 with no mention of broadband in the call
john46 | BT.com Help Site | BT Service Status
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Try a Search
See if someone in the community had the same problem and how they got it resolved.
Re: Frequent DCs
Thanks John,
Quiet line test - is quiet :-)
Moderator
Re: Frequent DCs
Hi @Taylor1892,
I'm sorry you're experiencing issues with your connection. I'll be able to take a look at this for you and run a few checks on your line. Please can you send me in your details using the "Contact The Mods" link found in my profile?
PaddyB
Community ModeratorPaddyB
Show your appreciation!
Kudos”
Make sure you are logged into the forum otherwise you will not see our contact link when a moderator offers help. When sending us your details please don’t send a Private message (PM), we can’t deal with account/service issues via PM so please use the contact link. Thank You
Re: Frequent DCs
Hi Paddy, Have you received?
Re: Frequent DCs
you would have received an auto reply with a reference number as soon as you sent the mods contact us form
the mods are very busy at the moment and are taking 3/5 working days to reply personally once the contact form is in their work stack
Try a Search
Re: Frequent DCs
I received a reference number on the 19th.
Thanks John - I will leave it another few days.
Re: Frequent DCs
They will get back you and own your problem personally until resolved
Try a Search
Moderator
Re: Frequent DCs
Hi @Taylor1892,
I've ran a few test on your connection following the engineers visit. Its looking pretty good at the moment, your profile is sitting at just above 18Mbps. I do think it would be best to monitor the connection for a few days to make sure it remains stable. I'll check back with you on Friday to see how the connection is preforming.
PaddyB
Kudos”
Re: Frequent DCs
Hi Paddy,
Thank you very much - pleasure as always.
Cheers,
CT
