Do you mean
Accepted Solution
Help! Network Addresses for Hub 3 needed
Can anyone assist me with the Network Address for Hub 3. At present I have these values for my Printer for the Sky Router;
IP Address 192.168.0.14
Subnet Mask 255.255.255.0
Default Gateway 192.168.0.1
What are the equivalent Addresses for the Home hub 3?
Thanks in advance.
Recognised Expert
Re: Help! Network Addresses for Hub 3 needed
Hi drmjfoster, Welcome to the Forums Smiley Happy
For the BT HomeHub 3, the Addresses will be as follows
IP Address 192.168.1.14
Default Gateway 192.168.1.254
I hope this helps
___________________________________
Like this post? Give it a Star Smiley Very Happy. If this post answers your question, please Mark it as the Accepted Solution.
Solved! Thanks. Its a pity the Hub's Book of words does not give this info - Again many thanks
Meant to give top stars - but did not have the hang of the numbers.
