Do you mean
Newbie
Help with connecting Nintendo dsi to internet
I really need some help with connecting my daughters nintendo dsi to the internet, I have tried everything but just can't get it to work. Would really appreciate any advice....
Distinguished Guru
Re: Help with connecting Nintendo dsi to internet
[ Edited ]
Hi sandy and welcome
Have a read http://bt.custhelp.com/app/answers/detail/a_id/11263/c/346%2C502%2C504/kw/nintendo%20ds/r_id/125731
Note: The Nintendo DS only supports either no security or WEP security!!
-+-No longer a forum member-+-
Newbie
Hi,
thanks very much for this, I've had a go but I still can't get it to work and my daughter is driving me nuts.   I've been into my home hub settings and it says it is running on WEP encryption and I have entered the key correctly.  It gives an error code of 051301-1 and 051300-1, do these mean anything to anyone?
Distinguished Guru
Although I've never connected the family kids DS's I believe that the DS needs to have a password that is either 10 or 26 characters in length.
Try changing the hub wireless password to 10 or 26 characters and let us know how you get on.
Newbie
Press the search button and on the panel press Network if do not see your Home Hub, on the search Bar look for Add a Wireless Device
