Do you mean
Home Hub 3
Hi,
I've decided to change my home hub 1 (white one with a phone) to a new home hub 3.
My first question is :
Do I have to uninstall the old Hub or is it just a question of changing one for the other?
My second question is:
The home hub 3 doesn't have a phone with it, does this mean I will not be able to have a separate broadband phone from now on? If so what happens to my old number?
Re: Home Hub 3
Hi yes just unplug tho old hub.plug in the new one change any wireless settings if used
As to broadband phone no you cannot use it any more and the number gets canceled
john46 | BT.com Help Site | BT Service Status
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Try a Search
See if someone in the community had the same problem and how they got it resolved.
