Do you mean
Accepted Solution
Home Hub Phone
Hi,
I have the BT Home hub phone I know that I can make calls free from this after 7pm during the week, am I correct in thinking that I can make calls any time during the weekend using the Hub phone and not be charged for this?
Please can you let me know
Re: Home Hub Phone
The blurb says you can make calls free all weekend using BT BB Talk. Don't forget if you are making long calls, hang up before 60 minutes to avoid being charged!
This is what the BT website says:
Your BT Broadband Talk is a great way to make and receive cheap calls over your broadband connection. It should be already set up ready to use.
  • Works like an extra phone line with no extra line rental
  • All UK* Evening and Weekend calls are included at no extra cost
  • Make international calls from just 1.25p a minute
  • Get great rates on calls to mobiles
