Do you mean
Expert
0
Hub 3 .38 software update
According to
http://bt.custhelp.com/app/answers/detail/a_id/32228/~/my-bt-home-hub-3-has-not-yet-received-the-lat...
the latest version of the HH FW is  4.7.5.1.83.8.48
However I am on .45, and the system has been powered on since last Tuesday (a week)
Normally it wouldn't bother me, but I've experienced 2 apparent crashes of the HH3 in the last 24 hours (looks like a complete reboot - ethernet and wifi connectivity lost, ssid disappears, returns after <2 min, no net connection, that returns another 30s or so later)
So there may be an instability bug here -- hence keen to ensure I'm running the latest firmware first before investigating further.
Expert
0
Re: Hub 3 .38 software update
I noticed the hub rebooted again last night. The log isn't especially interesting just showing
06:48:15, 09 Feb.Host 00:0e:8e:24:c3:7b connected to SSID 'planetf1e' at 162 Mbps
06:48:12, 09 Feb.( 32.420000) Ethernet is down after 0 minutes uptime
06:48:09, 09 Feb.( 29.350000) Server URL: https://pbthdm.bt.motive.com; Connecting as user: ACS username
06:48:09, 09 Feb.( 29.060000) Initializing transaction for event code 1 BOOT
06:48:07, 09 Feb.( 27.290000) Ethernet is up
06:47:53, 09 Feb.( 13.170000) Booting firmware 4.7.5.1.83.8.45 (Type A)
06:03:46, 09 Feb.Host 00:0e:8e:24:c3:7b connected to SSID 'planetf1e' at 144 Mbps
05:58:45, 09 Feb.Host 00:0e:8e:24:c3:7b connected to SSID 'planetf1e' at 117 Mbps
05:53:43, 09 Feb.Host 00:0e:8e:24:c3:7b connected to SSID 'planetf1e' at 130 Mbps
05:48:45, 09 Feb.Host 00:0e:8e:24:c3:7b connected to SSID 'planetf1e' at 144 Mbps
05:47:40, 09 Feb.(82831.930000) Time synchronized with server 213.123.26.170
05:47:40, 09 Feb.(82831.910000) Requesting time from server 213.123.26.170
05:43:46, 09 Feb.Host 00:0e:8e:24:c3:7b connected to SSID 'planetf1e' at 117 Mbps
So why the reboot at 0648 -- this is a similar time to yesterday, but also around the time the first client would connect...
Expert
0
Interesting -- exactly the same today, making it, I think - 3 days on the run.
The "reboot" is happening around the same time each day -- so could be scheduled rather than a crash.
Anyone else seeing this?
0
Im on the same firmware as you mate.
Had the router running for 24hrs, and so far no problems.
Is there a way to do a forced update does anybody know?
------Marc------
Expert
0
I've had an email response from the forum mods and asked the same question - either "pull" by me or "push" from tech support
For the first few days I had no reboots. Then the last 3 days I have. One thought I had is that it was a failed update - but I think first step is to get to what BT document as the "current" firmware (unless that info is wrong), then worry about remaining problems.
Even with these issues it's a dream compared to the HH2...
Expert
0
Does sound a bit like a failed update given that it is the same time each day.
Infinidim
Megadodo Publications
Ursa Minor Beta
If you want to say thanks for a helpful answer, please click on the Ratings star on the left-hand side
If the the reply answers your question then please mark as ’Mark as Accepted Solution’
0
I'll need to go on and check mine also, I had been getting an intermittant issue were it would say an ethernet cable is unplugged (PS3) but would correct itself within seconds, annoying when it happens in the middle of a movie I'm streaming.
Raid
0
Hi,
It may be something you have already tried, but have you performed a hard reset? Even if the sync drops on the hub, this won't necessarily force a firmware upgrade.
I've found that the firmware is only upgraded once a full reset is completed and before any synchronisation takes place.
Just an idea...
Kyle
If you found my post helpful, please give Kudos on the left!
Expert
0
Thanks. The mods have sent my question on to tech support, so will guess I'll see what they say now and not change anything for the mo.
Expert
0
Not certain if the hub booted again last night, but I think so:
06:49:15, 11 Feb.( 32.040000) Auto channel selection (reason 'Power up') is complete. Selected channel: 6, noise data: 1-(-114) 2-(-113) 3-(-112) 4-(-116) 5-(-113) 6-(-114) 7-(-111) 8-(-115) 9-(-115) 10-(-111) 11-(-120) 12-(-121) 13-(-121).
I can't be certain as I was up a little later, and the log is swamped by wireless log events (speed changes) - not that useful! So this is the earliest one I can reasonably see
Funnily enough this is the same time -- 06:49 again, or close enough...
still on .45
May wait to see if I hear back soon, otherwise as mentioned above it may be worth a hard reset (which shouldn't be needed of course)
