Do you mean
Newbie
Internet disconnects every 6-12 hours, download speed 283K.
Hi, first post so apologies if I miss anything...  For about 4 weeks now my router has been disconnecting from the broadband line approx every 6-12 hours.  I have a homehub 2, the 'broadband' light goes out before flashing orange and reconnecting.
The event log below is typical:
18:46:04   5 Jul 	xDSL linestate up (ITU-T G.992.5; downstream: 283 kbit/s, upstream: 612 kbit/s; output Power Down: 20.3 dBm, Up: 12.4 dBm; line Attenuation Down: 26.0 dB, Up: 15.0 dB; snr Margin Down: 8.0 dB, Up: 25.5 dB)
18:46:02   5 Jul 	[CWMP] Connection timed out
18:45:39   5 Jul 	xDSL linestate down
18:45:23   5 Jul 	PPP link down (Internet) [86.183.13.79]
18:45:15   5 Jul 	xDSL linestate down
18:44:50   5 Jul 	xDSL linestate down
 Router stats are as follows:
ADSL line status
Connection information
Line state	Connected
Connection time	0 days, 3:33:04
Downstream	283 Kbps
Upstream	396 Kbps
ADSL settings
VPI/VCI	0/38
Type	PPPoA
Modulation	ITU-T G.992.5
Latency type	Interleaved
Noise margin (Down/Up)	33.1 dB / 14.2 dB
Line attenuation (Down/Up)	26.5 dB / 14.5 dB
Output power (Down/Up)	20.5 dBm / 12.4 dBm
Loss of Framing (Local)	341
Loss of Signal (Local)	114
Loss of Power (Local)	0
FEC Errors (Down/Up)	14771 / 79
CRC Errors (Down/Up)	38 / N/A
HEC Errors (Down/Up)	N/A / 61750
Error Seconds (Local)	516
The router is attached to the test socket and I have tried a number of different filters with no difference.
There is a small amount of interference on the quiet line test with a corded phone but I'm not sure how 'quiet' it should be...
I have now had three faults raised and closed and I don't seem to be any closer to getting anything resolved..
Cheers
Tim
Re: Internet disconnects every 6-12 hours, download speed 283K.
if you tried the quiet line test then you should hear no noise and any noise will affect your broadband and you need to report a phone fault not broadband to 151- get this fixed and then sort your broadband
from your stats it looks like you are in a banded profile due to all the disconnections and you need to get rid of the noise to get a stable connection before you can get out of banding and get a better connection
once you get it fixed and with your attenuation I would expect a connection speed of about 17mb
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on left hand side.
hi you say you have noise on the quiet line test that needs resolving first as the test should be silent you need to phone BT Faults on 151 and report the noise but do not mention broadband in the call
once that is fixed then after 3 days stable connection your connection should be released from the banded profile you are in
john46 | BT.com Help Site | BT Service Status
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Try a Search
See if someone in the community had the same problem and how they got it resolved.
Newbie
Cheers guys, will try that and see what happens..
post back when you have more news
Try a Search
Out of interest, do the disconnections effect your network connection?  I always have to disable and re-enable mine.
Hi broadband disconections should not affect an internal network only the internet connection would be lost if web browsing
Try a Search
Newbie
My internal network stays up each time, I just lose broadband.
Further to this, I was suspicious of the corded phone I was using to check for interference.  Tesco value's finest corded phone gives a completely silent line on 17070 so I guess that side of things is OK after all.  Any other words of wisdom?
Thanks for all the responses so far.
Tim
is there anything on this post which helps
http://community.bt.com/t5/BB-in-Home/Poor-Broadband-speed/m-p/14217#M8397
Newbie
Long story short, I finally managed to persuade BT to send an engineer and it turned out that next door's tree was leaning on the phone line and disconnecting it every so often.  A new wire later and I have 16mb broadband...
