Do you mean
Distinguished Guru
Re: Is BT blocking PutLocker.com ?
Time for input from BT on this me thinks....
Though just tried and both putlocker and sockshare both still load fine for me - to date they've never failed to load
current settings
Default gateway:217.47.203.58
Primary DNS:217.32.171.22
Secondary DNS:213.120.234.10
-+-No longer a forum member-+-
Distinguished Guru
In case another reported issue doesn't get posted here, mods please also refer to this new post - http://community.bt.com/t5/BT-Infinity/BT-Infinity-and-Pages-Not-Loading/m-p/396895#M24967
I'm having problems reaching www.latimes.com !!
Have been using BT Infinity successfully for two months, but two weeks ago suddenly started to experience my browser stalling, websites not loading at all (eg www.latimes.com - simply will not load any of the home page), some sites loading but repeatedly not completing the download of all items (per message in browser footer).
I'm using iMac connected via ethernet to BT HH3 and BT Infinity. Problems occur regardless of whether I'm using Safari, Firefox or Google Chrome. Have tried restarting my router but problem persists.
Have scouted around various forums with a common suggestion being to change DNS server addresses etc, but not comfortable doing this unless generally accepted to be a robust remedy.
Any suggestions / advice gratefully received.
no problems with that site here on either mac or win 7 loads almost immediately
john46 | BT.com Help Site | BT Service Status
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Try a Search
See if someone in the community had the same problem and how they got it resolved.
there is no reason not to change DNS addresses
Try a Search
Newbie
Ok.
Contacted BT.  They disagree they are to blame for the non loading of Putlocker.
But heres what I tried after being loff putlocker for 5 days..
I use my movie site (let me watch this) and then I go to the links for my movies and then simply click all the links, one after an other and then 90% of the pages failed to load but 2 putlocker pages did and now  I am watching my movie on putlocker after BT kept me off.
Give it a bash and let me know if it works
[ Edited ]
OK, so it seems some people can access Putlocker but I cannot.
My computer and browser are fine...
because I can access PutLocker via using a Proxy IP address, so there is definitely a problem with my BT IP address.
It is worthwhile to note my IP address changes everytime I switch off my router so whoever is blocking the BT IP addresses, for Putlocker, is blocking a wide range of addresses.
So the question is.... who is doing the blocking?
It seems it can only be 1 of 2 options: PutLocker or BT.
The odd thing is that there is no notification from either party regarding the block.
Usually if a site blocks you there will be a notification stating your IP address is blocked, such as country specific websites which say: this site is not available in your country.
I cannot understand why Putlocker or BT would block me from the site, without explanation, but the blocking did begin shortly after Megaupload was closed down.
So, if I can access PutLocker via a Proxy Server, why can't I access the site via my normal UK based BT IP address?
My browser, router, and computer are all obviously fully functional thus the Proxy works fine.
[ Edited ]
I think what is happening is that BT are not actually blocking the site, they are simply throttling traffic to the site VERY HARSHLY, so harsh is the throttling that the site appears blocked. I suspect after MegaUpload closed there was a large spike in traffic to PutLocker and this is the reason for the throttling.
I have just managed to load PutLocker but it took around 4 or 5 mins to load the page.
Net-neutrality?
Moderator
Hi Guys,
Thanks for posting. If you’re having problems accessing the site try running a tracert and drop me and email with the details. You’ll find the “contact us” form in the about me section of my profile.
Cheers
David
Community ModeratorDavidM
Show your appreciation!
Kudos”
Make sure you are logged into the forum otherwise you will not see our contact link when a moderator offers help. When sending us your details please don’t send a Private message (PM), we can’t deal with account/service issues via PM so please use the contact link. Thank You
[ Edited ]
DavidM wrote:
Hi Guys,
How do I do this?
edit: ignore this I've done it
