Do you mean
0
My broadband download speed keeps dropping really low
Hi, In the last few months i've recognised a significant drop in the download speed of my broadband, Most of the time according to speed checks not even managing 1mbps when i have 16mbps broadband , I thought the router was the problem at first as i still had the home hub 1.0 and thought it wasn't able to take the speed, I have recently bought the home hub 3 which worked great for the first couple of hours then started to drop again i have also tried reseting the router which seemed to work for about an hour. The problems not just with the wired connection but with the wireless aswel, I have checked tons of posts for a solution but can't find an answer anywhere. Please Help!!!!
0
Re: My broadband download speed keeps dropping really low
Welcome to this customer to customer forum.
To enable forum members to help you, could you please read the web page that is shown below, which asks you to do a few checks first, and has some helpful hints.
When you have done that, please follow the instructions at the end, and post the results here, so members can offer advice. Thank you.
Speed and disconnections
0
Heres my speed test and adsl stats seems fast at the moment but keeps slowing down or dropping off at night and won't even load a webpage, hope someone can helpspeed test.JPGSTATS.JPG
hi please try to post a Full BT speedtest around 7pm and 10pm tonight that will help us to see any possible problems with exchange capacity
john46 | BT.com Help Site | BT Service Status
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Try a Search
See if someone in the community had the same problem and how they got it resolved.
0
Yet again was slow over wifi logged onto computer which is wired took about 15 minutes to load speed test website yet now seems fine again, anyways heres the results from about 15 minutes agotest 2.JPGassured.JPGSTATS 2.JPG
The BT speedtest must be done on a wired connection for accuracy the high number of errors will be reducing your download speed i would recommend having interleaving turned on that should reduce the errors
Try a Search
0
Yes it is a wired connection it seems to have dropped out again at the moment won't even load a webpage, How do I go about turning interleaving on?
0
Your downstream margin is much too low.
Take a look here Noise margins
and try the hint at the end.
If you still cannot raise the noise margin, then return here for advice.
Recognised Expert
0
[ Edited ]
The DLM has set the OP's Target Noise Margin to 3dB intentionally - Its a new setting for stable lines Smiley Very Happy.
99prarde, you have the exact same downstream attenuation as me at times (16.5dB) and with you being on the 3.0dB Target Noise Margin profile, you should be looking at around a 21-22Mbps sync on a good line.
I've noticed that you have a very high error count aswell and (As john46 as mentioned) interleaving should correct those (You will have to contact the mods to have it changed).
Have you tried to take a speedtest with your Homehub plugged directly into the Test Socket (If you have one) like the picture below?
If you have a spare, replace the Microfilter before plugging it into the test socket, to rule out a dodgy Microfilter.
Also make sure that you complete speedtests on a Wired connection, as Wireless can sometimes be the culprit with throughput issues.
I hope this helps
___________________________________
Like this post? Give it a Star Smiley Very Happy. If this post answers your question, please Mark it as the Accepted Solution.
0
[ Edited ]
But only for stable lines. In a number of cases already, this has been changed, at the request of the BT Care team.
Unless you have a very good line, a 3dB margin will result in excessive CRC errors, which will reduce the effective download speed. This can be seen by the ADSL line stats.
Interleaving would help, as it would introduce Forward Error Correction. That would be the first step.
If the OP cannot achieve a stable line at the current margin, then they can return here to have the target SNR increased from 3 to 6dB.
