Do you mean
My security key in Wireless Networking Properties keeps changing.
[ Edited ]
My security key in Wireless Networking Properties keeps changing. Itself to an eight digit key which I can't access. How can I stop this from changing itself, it started happening when I upgraded to infinity end of August beginning of September.
When I put in my wireless key info as printed on the card I get a reply that keeps saying the details are wrong, yet my wife has had no problems on her laptop for some reason it keeps defaulting back to this 8 digit code.
The operating system I am using is windows vista home edition
Help please this is becoming a bit of a nightmare .
Chris
Re: My security key in Wireless Networking Properties keeps changing.
Superscout,
You need to tell the operating system that you are using. That is windows xp/vista/7/mac.
Then someone would definetly help you.
Abhinav Rai
Sorry I should have said the operating system I am useing is windows Vista home ediition
