Do you mean
Newbie
0
Accepted Solution
Number of devices/connections to BT Home Hub2
Does anyone know ifthere is some sort of limitation to the number of simultaneous connections to a BT HomeHub2? As my kids get older and we get more tech I get the feeling that some devices are getting booted out at the expense of others - my eldest's XBOX I suspect is a major culprit. Is there an inbuilt connection priority on the hub? Can a connection priority order be managed? Is there a maximum number of connections? Do wired connections (ethernet) get priority over wireless connections? Basically, how is our BB capacity shared-out by the homehub? Try as I might, I'm struggling to find any detail on this.
Re: Number of devices/connections to BT Home Hub2
Not really, but the more connections, the slower it will get, and may need resetting from time to time.
There is no priority facility
Ethernet will generally give better performance. There is no limit on connections
Recognised Expert
0
Although i'm the biggest child in the house with my consoles x3 and Pcs. I took my son in the sales to buy his own xbox after he had saved for two years, I must say the slim connected wireless is a hungry beast for my connection.  Its the first time ive noticed a slowdown.
Mortgage Advisor 2000-2008
Green Energy Advisor 2008-2010
Charity Health Care Provider Advisor 2010-
I'm alright Jack....
Distinguished Guru
0
The only thing that gets priority is BT Vision.  Everything else just gets equal priority.
Distinguished Guru
The hub shares out data as it's requested. If you have 5 available meg and 3 devices are requesting 2meg each then it'll share it around and you'll see buffering if trying to stream media for example. There's no prioritisation as far as I'm aware.
BT vision prioritisation isn't done by the hub. It's done via something called QoS which is dealt with in the BT Wholesale network. You can use 3rd party routers with BT Vision.
As has been posted by Keith there is no facility to set priority and the more devices connected the slower the connection will become Unfortunatly there is nothing that can be done to improve the situation for you the only thing as time goes on and faster connections become available like infinity thecspeed losses per device will be come less but that depends on availability and cost if it is practical
john46 | BT.com Help Site | BT Service Status
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Try a Search
See if someone in the community had the same problem and how they got it resolved.
