Do you mean
PLEASE HELP! BT Home Hub keeps disconnecting.
Recognised Expert
Re: PLEASE HELP! BT Home Hub keeps disconnecting.
[ Edited ]
enter for homehub
192.168.1.254 in browser click A to Z top right
then ADSL enter pas and click MORE DETAIL
POST RESULTS
Also post results of test at ( best done from master test socket)
http://speedtester.bt.com/   if you can get it
Have you tried a quite line test
dial 17070 option 2 and listen - should hear nothing
best done with old type analogue phone digital will do but may have slight hiss
do not use home hub phone
If any post helps tick the star box on the left
Just cause Im paranoid dont mean they are not out to get me
Can't do a speed test, as I don't know my home number. However since, I've plugged it into the master test socket, it's been showing this error, in place of the amber error.
Recognised Expert
Ring a mobile from your home phone and you will get your number. If it shows withheld then dial 1470 before ringing the mobile.
Mine seems to be doing it too, could it be the snow here?.
Recognised Expert
It could be or the cold - do you normally suffer in bad weather.
We havent had this kind of snow for years tbh.
Found the number out and it's saying:
System Error Image not loaded
Performance Tester is unable to run the speed test for your telephone number:01442******. Please check that it is the correct telephone number for your service. Did you follow all the instructions given on the website, before initiating the speed test. If not, then please follow all the instructions carefully and try to run the test again.If you believe it is the correct number for your service and you have followed all the instructions then please ask your Service Provider whether you can use Performance Tester to test your Broadband speed. If yes, then ask him for the Service ID of your broadband connection and try again with this Service ID along with your Telephone Number. If this problem persists, raise the issue with your service provider.
It's definitely the right number, as I phoned my mobile from it.
I can't find a spare phone to test for noise on the line, however, I know that we've had problems with noise before. BT had come out around 2 years ago to fix it.
Seems to suffer all year round.
I've tried everything, it all works for a day or two then reverts back to it's old tricks, most times worse.
ADSL line status
Connection information
Line stateConnected
Connection time0 days, 1:02:47
Downstream1,056 Kbps
Upstream448 Kbps
ADSL settings
VPI/VCI0/38
TypePPPoA
ModulationITU-T G.992.1
Latency typeInterleaved
Noise margin (Down/Up)11.5 dB / 15.0 dB
Line attenuation (Down/Up)63.5 dB / 31.5 dB
Output power (Down/Up)15.8 dBm / 11.9 dBm
Loss of Framing (Local)13
Loss of Signal (Local)1
Loss of Power (Local)0
FEC Errors (Down/Up)82481 / 1
CRC Errors (Down/Up)2812 / 2147480000
HEC Errors (Down/Up)nil / 0
Error Seconds (Local)1527
