Do you mean
Port Forwarding for Minecraft
I have a BTHomeHub 1, and port forwarding minecraft has been an awful experience which I just can't get to work. I've tried everything, and just cannot get this to do what I want. mcft.jpg
this is what I have currently set up. Also, how do I tell what my computer is called on my network? I'm not sure if I'm forwarding to the right one.
Moderator
Re: Port Forwarding for Minecraft
Hi Mootwo14,
Welcome to the forum and thanks for posting. You can get some information on port forwarding on the Hub 1.0 here . Let me know if that helps.
Cheers
David
Community ModeratorDavidM
Show your appreciation!
Kudos”
Make sure you are logged into the forum otherwise you will not see our contact link when a moderator offers help. When sending us your details please don’t send a Private message (PM), we can’t deal with account/service issues via PM so please use the contact link. Thank You
[ Edited ]
You need to go to network devices at http://192.168.1.254/cgi/b/devs/cfg/?ce=1&be=1&l0=4&l1=4
Then click Edit which shown on the right of the device interface column.
At the bottom of the page where it says "connection sharing", select the Mcft from the list of applications, then click "apply".
That will assign that application to the device.
You can view all assignments here http://bthomehub.home/cgi/b/games/cfg/?ce=1&be=1&l0=4&l1=5
Forumhelp (Private website) Lots of additional information for BT Residential Broadband connections only.
Newbie
How can you do this for bt home hub 3
