Do you mean
Problems running BBC iPlayer on Samsung Monte using myBT HomeHub2 Wi-Fi connection
I have a Samsung Monte phone and a BTHomeHub2 router. When I use my phone to try to play any TV program via my home wi-fi network, nothing happens and I eventually get a message saying th connection to the server was lost. However if I go into the BT Home Hub Manager application and disable my router firewall, iPlayer works fine. Obviously I'd prefer not to completely disable my router firewall, so are there any tweaks I need to make to it's configuration to specifically allow BBC iPlayer to operate correctly on this device?
