Do you mean
Expert
Removing the Bell Wire...
I have read on the internet that removing the bell wire can improve your broadband speed. All the guides on this are on the old sockets. I have a new filtered socket, I have taken the faceplate off and I can see that a wire is connected to terminal 3 which is where the ring wire is connected. If I remove this wire, is it safe and will it make any difference?
If my answer was helpful, please give me a star by clicking the star on the left hand side.
Thank you.
Re: Removing the Bell Wire...
The new filtered sockets already have the bell wire removed. Which master socket do you have.?? and is the wire connected to terminal 3 orange and white. ??
Expert
Here is a picture of it: http://www.google.co.uk/imgres?imgurl=http://ecx.images-amazon.com/images/I/51PWOlMK65L._SL500_.jpg&...
Thank you.
Expert
Their is a wire connected to terminal 3, but it's not orange and white. It's green.
Thank you.
Yea those ADSL filters already have the bell wire removed so that green wire must be in use i wouldn't go tampering with it just incase you mess something up and you dont want to have to call out a BT engineer because we all know what happens when he comes out. ££££££ !!! Smiley Happy
