Do you mean
0
Re: Slow Steam Downloads (Gloucestershire)
I think this is what your looking for;
 IP Profile for your line is - 2 Mbps
0
[ Edited ]
That is what the problem is, you may have a stuck IP profile. I will move this thread to the ADSL board, so that more in-depth results can be looked at.
0
What are your ADSL Statistics ?
Then forum members can see whether your IP profile is stuck.
0
Sorry gents bit lost here.
Stuck IP and all that makes no sense?
0
Your IP profile is linked to your connection speed, but it can become stuck at a low value, which will make things slow.
Once you display your ADSL connection speed here, then its possible to determine if that is the problem.
0
can you run btspeedtester again but this time when first test completes run the diagnostic test and post all the results please
btspeedtester
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on left hand side.
0
 Download speedachieved during the test was - 2.14 Mbps
 For your connection, the acceptable range of speeds is 0.4 Mbps-2 Mbps.
 Additional Information:
 Your DSL Connection Rate :8.13 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
Hope this helps, thanks for the reply Smiley Happy
0
certainly looks like profile stuck as it should be 7.15mb with your connection speed.  now need the adsl stats that Keith asked for to see connection time
0
Sorry for the slow reply gents, had to reset the router as the partner's father couldn't remeber his admin password. Anyway, hope that won't affect anything;
ADSL line status
Connection information
Line stateConnected
Connection time0 days, 0:06:38
Downstream8,128 Kbps
Upstream448 Kbps
ADSL settings
VPI/VCI0/38
TypePPPoA
ModulationITU-T G.992.1
Latency typeFast
Noise margin (Down/Up)12.3 dB / 22.0 dB
Line attenuation (Down/Up)5.0 dB / 3.0 dB
Output power (Down/Up)7.8 dBm / 11.9 dBm
Loss of Framing (Local)0
Loss of Signal (Local)0
Loss of Power (Local)0
FEC Errors (Down/Up)0 / 0
CRC Errors (Down/Up)1 / N/A
HEC Errors (Down/Up)N/A / 0
Error Seconds (Local)1
0
ok you now need to be able to show a 3/5 day stable connection and if your IP Profile has not risen automatically then the forum mods could intervene and carry out a manual IP Profile reset but they have to see a stable connection first
john46 | BT.com Help Site | BT Service Status
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Try a Search
See if someone in the community had the same problem and how they got it resolved.
