Do you mean
JMB
Sony Vaio loses wireless connection to Internet
I use WiFi to connect my Sony Vaio laptop to my BT hub. Quite regularly I find it loses the wireless connection to the Internet, it usually shows that still connected to the hub but no Internet connection. I think the hub is working OK because another PC on wired connection is OK and another PC connected by wireless at the other side of the house is usually OK. I usually can fix by rebooting the Vaio so I think it is a Vaio problem but wonder if anyone has any similar problems? MB
MB
Expert
Re: Sony Vaio loses wireless connection to Internet
Hi JMB
I am also a vaio user too, i have had my problems but normally driver updates resolves the problem.
What model of Vaio have you got and what version of Windows are you running?
I use a small .bat script which resets my wireless internet, open notepad and copy the following text and save as reset.bat
c:
cd\
cd windows
cd system32
ipconfig /release *Con*
PAUSE
ipconfig /renew
PAUSE
This normally fixes most of my issues ;-)
CG Over An Out
Recognised Expert
Try the hub wifi as BG only not N bands
or
get a cheap usb wifi stick
If any post helps tick the star box on the left
Just cause Im paranoid dont mean they are not out to get me
Expert
My bro in law had to get a wifi stick for his lappy (Acer) tiny little things they are now aint they.
I believe he paid about £7 for it and it works much better than the onboard wifi
An MSCE in computing is like having a McDonalds Certification in World Cuisine, pointless.
