Do you mean
TP-Link TD-W8961ND Wireless-N ADSL2+ Modem Router - Version 2
has or are anyone using this TP-Link TD-W8961ND Wireless-N ADSL2+ Modem Router - Version 2 instead of the bt home hub 3?  i need some help because all i get is dropouts after i have set the settings up in the device i use the defualt settings advised in the set up instructions tp link give, ive been told my line adsl may be to slow for this kind of adsl router. so have for now gone back to the hhub 3 here are the results from the nhub3 today. can someone explain this to me G.992.1 Annex A
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.1 Annex A
Latency type:Interleaved
Noise margin (Down/Up):8.7 dB / 24.0 dB
Line attenuation (Down/Up):48.3 dB / 29.5 dB
Output power (Down/Up):19.3 dBm / 12.2 dBm
FEC Events (Down/Up):585803 / 1
CRC Events (Down/Up):347 / 3
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
HEC Events (Down/Up):1822 / 0
Error Seconds (Local/Remote):196 / 4
Re: TP-Link TD-W8961ND Wireless-N ADSL2+ Modem Router - Version 2
992.1 is adslmax up to 8mb
992.3 is adsl2 up to 12mb
992.5 is adsl2+ up to 20mb
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on left hand side.
The connection speed is missing from those hub3 figures.
G992.1 is ADSL max, up to 8Mb, which is compatible with all routers. Perhaps you have the settings wrong on the TP link one.
There is some information on this page, which should also apply to the 8961ND.
Using the TP-Link TD-W8960N instead of the BT home hub
You can ignore the DNS settings and leave them at default, if you do not want to use OpenDNS.
Forumhelp is back online. Some links may be out-of-date, but I will update them when I get time.
thanks for the quick reply so im on a slow line in reality but i thought the tplink would work ok i got it to improve the wireless signal over the hhub3 but because the internet keeps dropping out i have gone back to the hhub3
Line state:Connected
Connection time:1 days, 01:48:58
Downstream:3.688 Mbps
Upstream:448 Kbps
It should work fine, a number of people here are using the 8960N without problems.
Was the actual broadband (DSL) dropping out, or did it just keep losing authentication?
Did you make sure that it was set to PPPoA and not PPPoE?
