Do you mean
0
Accepted Solution
Talk21 account
I have an old talk21 account that I still use and I have seen three options in order to setup pop and fowarding which are:
Upgrade to Premium Mail
Upgrade to Broadband
Upgrade to Anytime
Since I already have BT Broadband would there be any chance of having it upgraded to premium mail without paying for it, or would I have to bite the bullet and pay to have it upgraded?
My Motto:
Going to kill my HomeHub 2 very soon. Smiley Happy
Distinguished Guru
0
Re: Talk21 account
Upgrade to Anytime
Hi.
Talk21 accounts used to be also accessrd via username.t21 [AT] btinternet [dot] com, so it should be possible to add this account to your main broadband account. It depends if the talk21 email address is deemed as a "webmail" only account. You could try logging into http://mail.yahoo.com using the whole email address I mentioned above as the Yahoo! ID and the password and see what happens.
I don't know specifically if it's needed, but in order to send emails "from" this account using @talk21.com as the account email address - you may need to do something called "address verification" - see my shortcuts option 0e for some details if needed.
0
Re: Talk21 account
u can call Bt yahoo billing team and informe them that you have got the Broadband account and have got the narrowband email address,
they will change the details in a tool called IDA and upsell the details to Broadband. so this willbe broadband email
0
Re: Talk21 account
Yeah I'll give your suggestion a try as the last one didn't work for me.
My Motto:
zeg
Newbie
0
Re: Talk21 account
Hi,
For security, I recently changed my password on my talk21 email account.  I checked it was working immediatley after the change but today cannot log in using the new (or old) password.
I have now been locked out and given detention for 12 hours.
I cannot remember my security questions as it is a very old account. (in fact
I dont remember giving any around 12 years ago).
Any suggestions would be most helpful. I'm wondering what has changed?
Should I be logging in with a Yahoo suffix now or what?
0
Re: Talk21 account
this subject is marked as solved and is 18month old.  replies should go to your own subject rather than this old solved case
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on left hand side.
